Question about Panasonic Audio Players & Recorders
Sa-ht545 error code f61- comes up upon statrting
  • 6,487 Answers
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
Posted on Jul 09, 2008
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: sa-ht545 error code f61- comes up upon statrting
No not that much.. but having it repair will be better than getting a new one..
Good luck.........
Posted on Jul 10, 2008
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Would any one be able to get a part #, cost for the regulator, for my Panasonic SA-CH94M? I believe this is the culprit with the F61 error code. Thanks!
the F61 error on panasonic home theatres can mean 1 of 4 things, its either you have the wrong speakers plugged into the wrong port (yes apparently this matters check correct speaker placement), the fans are not working at all or working poorly (simply clean with circuit board cleaner or replace fan you may have 1 or 2) if none of the above then you have the worst one wich is one of your power amplifier IC chips somewhere on the main circuit board has died (good luck fixing that one) obviously varies from model to model this is based on th SA-HT545 and the SA-PT450. Sometimes a new HDMI cable will solve this issue.
If the cables are good, then the easiest possible fix would be to clean or replace the rear electric fan. I had the same problem and after replacing the fans my unit works like new. I called panasonic to order the fans because these type of fans you can not buy out of any store. The rear fan is also an upgrade to a better bigger fan. Part numbers are: L6FAJCCH0007 $19.12 (side fan) RFKZHT540E $28.35 (Rear fan) total shipped to me was $61.43.
Happy Holdays! Dont forget the feedback! Thanks!
Dec 18, 2010 | Audio Players & Recorders
I have a SA-HT545 DVD home theater sound system and it shows F61 error. How can I fix this?
The F61 is the Panasonic code for protect mode. See the link below for an explanation of protect. In your case, there is an output amp pac that has failed. The cost for this ranges from $75-$100 for the part. Please update this if you are interested in repairing this unit and I'll get the exact parts required.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Nov 01, 2010 | Panasonic Home Theater System System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
I have an issue with Panasonic SA-HT545 Surround sound system and it keeps coming up with f61 problem and its not working now
I have a similar unit about 18 months old...just wouldn't start and gave me the F61 code. I opened it up and found that the fan on the back was not running properly...the fan's circuit feeds back info to the cpu that it is running...when not it shuts the system down. I powered the fan externally with a 20v power source and ran it for a while off the red and black wires (the yellow wire must be the feedback)and re-installed it. All is working fine...but I'll go out and buy a new FAN.
Jan 29, 2009 | Audio Players & Recorders
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Good luck.........
Jul 09, 2008 | Audio Players & Recorders
F61 on SA-HT545
I can not find a listing for model SA-HT545. All I can suggest is that there should be a large black IC attached to a heatsink that should be marked STKxxx or something similar. Post that marking here and I'll confirm that it is the correct one to replace. That part is the output amplifier pac and is the most common failure part that generates the symptom you describe.
Keep me posted.
Dan
May 25, 2008 | Panasonic Home Theater System System
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Jan 10, 2008 | Panasonic sa-ht800V Home Theater Audio...
470 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
