Question about Vizio E470VA 47 in. HD-Ready LCD TV
I just bought a 47 inch vizio and I noticed when the screen is dark(like during credits of a movie, for example) there's cloudy white areas around the sides. Is this normal? $658 online 7 reviews VIZIO's E470VA 47" class LCD HDTV delivers full 1080p HD picture quality and superior audio at an amazing value! This flat screen LCD HDTV features 120Hz refresh rate for razor sharp clarity, SRS TruVolume and SRS TruSurround HD audio for advanced virtual surround sound, 50,000 to 1 dynamic contrast ratio giving you deeper blacks and brighter whites, and four HDMI ports to connect up to four HDMI devices to your TV.
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
SOURCE: Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Posted on Mar 18, 2010
SOURCE: How do I get a full picture on my vizio 47 inch.
you need to check the resolution on cable box
and check the format botton in remote control
Posted on Nov 17, 2010
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Posted on Dec 15, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a vizio 47" lcd tv that was affected by a
I believe the main baord is bad (main board contains the inputs circuits, tuner, sound and video processor).
http://www.shopjimmy.com/vizio-3642-0722-0150-main-unit.htm
http://www.shopjimmy.com/vizio-3647-0102-0150-main-unit.htm
You may want to look inside to see if you can see any burnt components.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 23, 2011
Dark bands on lcd tv
Hello
If it is new, exchange it atonce. The Timing Control Board [T'Con] boar is faulty. It is womehat costly. Will cost around $29 or so.
Feb 06, 2012 | Vizio XVT3D474SV 47 in. 3D LCD TV
We just purchased our 47" vizio television today.
i recommend not to fix anything by yourself since you bought new and the tv is under warranty. please contact authorized service or seller first.
Feb 27, 2011 | Vizio VO47L 47 in. LCD TV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
51'' Philips rear projection TV with color issues
Philips has had a big problem with there coolant fluid becoming cloudy. The only way to clear it up is to have the fluid changed. With every projection crt tv there is a layer of cooling fluid between the face of the crt and the lens. This coolant cools the face of the crt. Over time the coolant breaks down and the light coming through gets distorted. The crt's have to be removed from the set to do this.
Oct 13, 2009 | Televison & Video
Dlp has dark blue areas on screen
Have you tried magic focus? if that doesn't work
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Jan 22, 2008 | Samsung HCN4226W 42" Rear Projection...
Hitachi 57F500, Dark areas
Hitachi dark problems at ctechnicians.com
Dec 27, 2007 | Hitachi 57F500 57" Rear Projection...
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
Vizio E470VA 47 in. HD-Ready LCD TV Logo
161 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
