Question about HP PSC 2110 Color Printer
Scanner and....ink? ok so i put the picture in to scan and i sat and waited but nothing happened so i looked at the little screen on the top of it and it says that the scan failed and i need to take out the ink cartrage and i do then i try agian and it tells me to check my ink thing and that i should take it out and then put it back in and then it tells me to to do the same thing over can anyone tell me whats wrong pleez
    Genius:
  • 1,689 Answers
Try a new ink cartrige set. If there is still a fault, then there is a hardware failure in the unit.
You can try calling the HP tech support. I think for their first answer, they will tell you the same as what I am suggesting.
Jerry G.
Posted on Jul 09, 2008
How to install new ink cartridges and how to take out old ink cartridges
If you have some cartridges that aren't empty, first make sure that the printer is on. Then press the Menu button and navigate to the Maintenance menu then select Ink Cartridge Replacement. Press OK. Make sure that the document cover is closed then lift the entire scanner unit (grip it on the sides). If the cartridge carrier moves, wait for it to stop.
Then squeeze the tab at the back of a specific cartridge and pull it straight up. (Have one finger on the tab and another finger or thumb pinching the opposite side of the top of the cartridge.) Prepare your new color cartridge by shaking it 4-5 times then open the bag. Remove the yellow tape from the cartridge without touching any other parts of the cartridge. Then insert the cartridge into that slot and press down until it clicks. Repeat this for the rest of the ink cartridges.
Finally, lower the scanner unit and press OK on the keypad to exit the maintenance mode. Wait for the printer to do its ink system test routine. Cancel any print or scan jobs that were in progress before you changed the ink.
I hope this helps. Pictures to go with the above description are in the user's guide starting on Page 177. It's available here: https://files.support.epson.com/pdf/wf2520/wf2520ug.pdf .
Feb 15, 2015 | Epson WorkForce WF-2530 All-in-One...
Canon MP340 won't scan
The printer "black ink low" message has nothing to do with scanning. You don't have to disable the ink monitoring or do anything else with printer - to scan!
The printer is" waiting" for you to CLOSE a "Paper port 11" dialog box on your PC screen. If the dialog box is not open, check the task bar (bottom of screen) for anything with "MX340" in title, click on it then close it.
good luck
Lumir
www.inkbank.com.au
Mar 09, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My cannon printer MP270 series wont scan anymore, and on the surface al looks good, nothing seems damaged, and the glass on the top is OK. But now an alarm is marking, and of course im missing a black ink...
Some of these units will not work if there is an issue with an ink cartridge or if it is missing. reinstall it and see what happens after you do a hard reset on the printer
Sep 12, 2017 | Office Equipment & Supplies
Launch Nikon Coolscan, but browser/scanner window doesn't open
I think the scanner may have got confused and be expecting another adaptor to be connected. If you slot in the single slide adaptor, wait until all the scan functions become active on-screen, then remove that and insert the SF-210, you might find it works OK.
Jeff Underwood 1scan.co.uk
Nov 16, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Kodak easy chare 5100 scanner
kodak is the worse i have the same problems just wait till you need new ink
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Wont scan somthing with ink cartrage
Please reinstall the printer driver .
Jul 09, 2008 | HP PSC 2110 Color Printer
Help!!!
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Mar 18, 2008 | HP Photosmart D7160 InkJet Printer
Sanning problems for printer PIXMA MP 160
some printers can detect that the cartridges are refilled based ona barcode or scanning of the cartridges. Does this Cannon have ink tanks or ink cartridges. If it has intakes then the print head needs to be cleaned wth rubbing alcohol and a q-tip. If they are cartridges then it would be good just to buy the original cartidges. As far as the scanning goes this can be a direct connection to the printer going through maintenance. If it continues to not scan then you may need to uninstall the scanner. see if the scanner shows up in your scanners area. if not then it will need to be re-installed.
Feb 13, 2008 | Computers & Internet
Solid background tint
I bought a power supply from ebay paid $22 with shipping thought it was better than getting a new scanner.
Screen is all Green and resolution is 72 no matter what the settings.
I guess it is time for a new scanner.
Dec 25, 2007 | HP Scanjet 5470c Flatbed Scanner
HP PSC 2110 Color Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
