Question about DeLonghi Heating & Cooling
I have a pacw160 and it is not using any water can u help
Can I use karcher water suction hose with karcher k.26 ?
When using harvested water, it is most important that the water supply is above the machine. The gravity will help a lot. The higher the better. Also if the diameter of the supply hose is big, it will help the output flow.
Regards,
MG.
Oct 11, 2014 | Karcher Garden
Metallic tasting coffee
You need to look in your manual and descale the unit. When you do this, make sure you use vinegar and water. This will take care of most of that. Also when filling your machine with water, if you use bottled water or going through a good water filter system will help this. So, between descaling the machine, with vinegar and water, and filtered water will help this go away. Thanks Mike
Please rate my solution if this was helpful. Thanks.
Sep 30, 2011 | Keurig B70 Coffee Maker
After a few months use there is a green algae like growing in the bottom of the water container. I am using filtered water. Is this normal and Is there a solution?
Using filter water of course helps keep things clean and so forth. To help solve this algae problem when you descale and clean machine use vinegar and that should help from algae building up. Thanks Mike
Sep 14, 2011 | Keurig Elite B40 Coffee Maker
Have SDX23VW - water leaks from rear bottom when dispensing water; also, seems t/b leaking when water flows into ice maker (hear water flowing) & water dispensing not used.
Hello, Thank You for using FixYa. I will be helping you today.You have a crack in one of the water lines or the valve.Have someone press the dispenser while you find the leak in back.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Amana SXD524VW Side by Side Refrigerator
What type of water should be used for a model#JP8100CB, serial#1622072 Oreck cord/cordless iron? Tap water or distilled water? Thank you very much.
The best water to use is water that does not contain minerals. Distilled water, can be used in your iron for years without causing any buildup or clogs.
Hope helps.
May 13, 2011 | Irons
Can I use tap water for formula bottles? If there are additives in my tap supply I need to watch out for, how can I tell/test if they are in my water?
IF YOU HAVE CITY WATER OR THERE SHOULD BE NO PROBLEM. IF YOU HAVE WELL OR SPRING WATER YOU CAN CONTACT YOUR LOCAL WATER PLANT AND THEY CAN TEST THE WATER. IF IT IS POWDER FORMULA, I USED THE DISTILLED WATER YOU CAN BUY FOR ABOUT $1 PER GALLON AT YOUR LOCAL SUPER STORE.
Mar 30, 2011 | Baby Care
My keurig says descale
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Coffee Makers & Espresso Machines
How do you change the water filter?
Their is no water filter to change, you should try the below to clean the unit
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Keurig Special Edition B60 Coffee Maker
It says to add water and it is full of water
Sorry to read about your problem, I hope this helps you out.
just try and reseat tank plus this
Dec 17, 2010 | Keurig B60 Coffee Maker
Heating & Cooling Logo
70 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
