Question about Pentax PocketJet 3 Thermal Printer
Pentax PT-A4303A I just got the bare printer Body and 3 cables. I ca'nt find the User's Guide; Where can I find it?
I don't have an instruction booklet for the P-Touch 1100 and I need to change settings for different size letter sizes. are you able to email me an instruction manual.
Hello Steven,
I can't email you a manual however you can easily download the PDF version of the manual on the Brother website at www.brother.ca
Please use the below link to your user's guide.
Please note that the PT-1100SBPV has been discontinued and replaced with the PT-1180 model. The manual should be almost identical.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/doc/manual_index.html?reg=us&c=ca&lang=en&prod=1180eus&dlid=&flang=English&type2=-1
Thanks,
Pat
Apr 14, 2011 | Office Equipment & Supplies
Hi user guide missing
http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/MCB146-05-_D
click on download the complete user guide
Jan 14, 2010 | Audio Players & Recorders
Hello, Every time I try to print it just puts it on pause and it won't let me start it up again. Also if I try to get on to the user guide page it says "Cannot open file:...
hi jkearns92,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 11, 2009 | Dell 924 All-in-One InkJet Printer
Broken connector cable for Pentax Optio 450
Yes. The cables are sold too. I got a deal by buying a dock from compgeeks.com and it was cheaper than just the cable. So, go shopping.
Aug 30, 2005 | Pentax Optio 450 Digital Camera
Pentax PocketJet 3 Thermal Printer Logo
197 people viewed this question
Top Pentax Office Equipment & Supplies Experts
Johnny Massengill
Johnny Massengill
Abdul Mannan
Abdul Mannan
Are you a Pentax Office Equipment and Supply Expert? Answer questions, earn points and help others
