Question about Jl Audio 15W3-D4 Car Subwoofer
Hi, I have 2 JL 15 W3s, and the Foam around Both Subs have ripped and Tore off From the Speake... How could i Repair it Myself??
zzedly
  • 300 Answers
SOURCE: jl audio 12w3v4....both smoked and fried on a 500/ jl amp
Unfortunately, it sounds like the voice coils burnt up. There are places that do repair, but for these particular subs, it would be more cost efficient to replace them. I also doubt they are salable, but ebay is a magical place.....
Posted on Mar 05, 2008
pjstanley
  • 185 Answers
SOURCE: one of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
SOURCE: surround seperated from subwoofer
My JL 0"s have the same issue. I'm gonna try buying a foam repair kit i found on eBay.
The repair kit for yours can be found at this link:
http://cgi.ebay.ca/JL-Audio-12W3-Subwoofer-Foam-Repair-Speaker-Refoam_W0QQitemZ300221230112QQihZ020QQcategoryZ3276QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262QQ_trksidZp1742.m153.l1262
Best of luck to you and me!!!
W5RK
Posted on Sep 11, 2008
SOURCE: how do you wire up the voice coils on the w3 subs i have 4 jl 15s
Hi their the best link ever to wire up subs is this:
http://www.crutchfield.com/S-s8dIAxJtgx2/learn/learningcenter/car/subwoofers_wiring.html
Posted on Apr 10, 2009
Sphynkter
  • 221 Answers
SOURCE: i have a little rip on the subs ring
The little rip on the foam surround can be repaired easily with some pure silcone from a harware store. Make sure it's pure silicone, because the silicone mixtures may deteriorate the foam prematurely. Also, all you're really doing is plugging the hole that the rip makes so that air doesn't leak out and further damage the surround and also affect your sub's performance. You'll need to apply a thin to moderate coat of silicone to the rip, and make sure that some gets into the rip. Do NOT use globs or big lumps. You should apply some silicone to your finger, and carefully apply it to the area. Try not to get too much on the inside/backside of the rip. If you'd rather just get a replacement sub, you should be able to find the raw driver on eBay or at a local MTX dealer.
Posted on May 18, 2009
JL W6 ohm wiring issue
Parallel , all positives together , all negatives together . With 4 ,4ohm voice coils in parallel you get around 1 ohm .
Apr 23, 2012 | Jl Audio Car Audio & Video
Ok i have a jl500/1v2 amp with 2 w6v2 subs and i haveing a problem dont no if the amp is two much for the subs becouse i turn the amp to get more tump and the subs pop and the yellow light filkes so i turn...
its real simple. your under powered.
your W6s RMS at 500 watts EACH and your sending em 250RMS (half what they need)
The 'pop' your hearing is the failure to supply enough power to draw the cone back in time and collides with the next wave of sound.
prove it?
drive a single W6 with your 500/1 bridged.
i'll bet your pop goes away.
long term, get another 500/1 or jump up to a 1000/1v2.
I also HIGHLY recommend JL's in-line audio cleaner. If i recall it was like 60 bucks but waaaay worth it. makes sure that theres no distortion in the source input to your amp(s), which...keeps your subs from trying to reproduce transients and delivers only clear signal to your subs void of all clipping signals. Its an active electronic compoent.
PS: if you are pushing 12W6's, i had the same setup once...I had W3s connected to my 500/1 and upgraded to the W6s...had the same issue your describing, and then got the 1000/1. happy ending.
May 03, 2011 | Jl Audio 500/1V2 Car Amp
It is rip in to little piecies
It may not be worth the expense, but if the cone or surround are torn, they can be replaced by a speaker repair shop. I just had a pair of JL 10W6's re-edged (the foam surround around the cone deteriorated after 11 years), and the repair cost $100 for the pair, including parts.
Nov 01, 2010 | Thump TBB102 Car Subwoofer
The foam surround on my subs are cracked and torn. I need them repaired. Would it be more ideal to buy new subs or get these w7's repaired?
wow i won't throw them away or anything like that. You can always go down to your local JL Audio dealer to see how much to refoam the subs. Lot cheaper then buy new ones..... That's the way i would go.. Hope this was helpfull
May 20, 2010 | Jl Audio 13W7 Car Subwoofer
Most power out of amp w/out blowing subs
you may only be able to get but so much out of the subs. If you turn the bass down a little so the that you dont drive the subs so hard you may get a little more wattage out of them
Apr 06, 2009 | MTX Thunder 1501D Car Audio Amplifier
Surround seperated from subwoofer
You can order repair kit here:
http://www.simplyspeakers.com/2doityourself.htm
Aug 02, 2008 | Jl Audio 12W3 Car Subwoofer
Which Jl Audio 12 Has No Writing On The BAck
http://www.simplyspeakers.com/speakerrepairinstructions.htm
go with the repair .those r good subs,very expensive. i repaired a pokl 12" sub cone and surround foam. never had a problem. save me 300 bucks.the cone you can fix by using the same material that it is made off.if paper use rubbeer glue. if plastic ,i used a 2 part epoxy,airplane glue.didn't look pretty but did the job.rating please
Feb 03, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Amp turns on but there is now sound
Check this out: http://www.techlore.com/article/14696/
Aug 14, 2006 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 15W3-D4 Car Subwoofer Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
