Question about Cycling
To reset Smart cycle computer - Cycling
Fitted smart lock module under dash now want to reset remote on au falcon
The official workshop manual Suggests:
  1. Close the doors.
  2. Turn the ignition key to the accessories position.
  3. Within 5 seconds of turning the key, hit the rear demister button (center console) three times in succession.
  4. The door locks will cycle once to indicate the special mode has been entered.
  5. Press any button on the remote you wish to program.
  6. The doors will cycle to indicate a new remote has been programmed.
  7. Continue steps 6 and 7 for all remotes (including existing ones) you intend to use on the vehicle.
  8. When you've programmed all the remotes, turn the ignition key off. The doors should cycle again to indicate the programming session has been completed.
Jan 25, 2015 | Smart Cars & Trucks
Wrong resolution on smart tv- cvd601
I made the mistake of selecting the largest of the resolution settings of 1920x1080-50Hz. The CVD601 DOES NOT HAVE A RESET BUTTON! You have to do all your business on screen. So to regain my setting of 1280x720-60Hz, I disconnected from my TV and hooked up to my computer monitor. At that point, I got my picture back and went to settings. Upon restoring the settings in TV Screen Resolution to: 1280x720-60Hz just click and exit. In the US everything is based on the 60Hz cycle. Hence the hickup when you pick anything in the 50Hz cycle. I hope this helps!
Jan 08, 2014 | Craig Electronics Craig Smart TV HDMI...
How to hook up smart cycle
There is no power cord. There is a battery compartment on the underside that hold 4 D size batteries.
Jul 23, 2012 | Fisher Price Fisherprice Smart Cycle...
"smart cycle extreme" electrical cord
Here you go. The cord is the last item on the list. Hope it works out!
https://store.mattel.com/ProductParts.aspx?cat=139&sec=8713&productid=N9628&tx=103
May 08, 2011 | Fisher Price Fisher-Price Fisher Smart...
I have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
i have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
Sep 21, 2010 | Washing Machines
Way to reset the user name/password
only thing i ran into was this: try it.
Default Password for APC Smart UPS
Description
Manufacturer APC Protocol Multi Access Admin Model Smart UPS User ID apc Password apc
Feb 19, 2010 | Enterasys APC Smart-UPS 2200 XL...
Not getting power to a 580 smartboard.
if you have no led, the board has no power. you can only have 4 usbs in one hub, and each of those usb cables cannot be over 16 feet long. if it's red, it's not communicating with the computer. check the usb port on the computer. disconnect the usb fron the board and reconnect it. if it's amber, there is a checksum error, so reset the SC9 controller by pushing the reset button on the side of the SC9 for no longer than 3 seconds. if the pen tray leds cycle, all should be well.
Jul 14, 2009 | Smart Technologies SMART Board 580 (SB580)
Need parts list for fisher price smart cycle
The child has wrapped the connector cords around one of the pedals of his Fisher Price Smart Cycle and it has completely severed the cord from the cycle. Is there replacement parts for this problem?
Feb 20, 2009 | Fisher Price Computers & Internet
ABS and Traction control stay on after smart car is started
Although I am unfamiliar with the smart cars, it sounds like you just need to reset your computer. Remove the negative cable from your battery, then flip your lights on, pump the brakes, press the horn. What this will do is drain all the capacitors including the ones in your computer. Ultimately it will reset your computer (aka turn off the ABS and TC light) hope this is helpful and good luck
Feb 04, 2009 | 2008 Smart fortwo
Cycling Logo
290 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
