Question about Pride Celebrity X 4-Wheel Electric Scooter
I have a 150KG hoist fitted to my 4X4, what is the best way to lift my Celebrity X 4 Wheel scooter as there appears to be no lifting lugs. Do I buy straps, or are there other methods.using straps? I live alone and have no one to assist in dismantling the scooter, even so the parts would be too heavy for me to lift. thanks for any help. BJ. Hopkins
  • l99bjh Jan 02, 2011
    Thank you this is helpful however, you mention proper straps have you any recommendations and a source of supply? I am in the UK.
    BJ. Hopkins
    Great stuff! thank you.
    President:
  • 1,139 Answers
I would definitely recommend buying some proper straps as this is by far the safest way to raise the scooter. Make sure you get at least 2 straps so that you can position one towards the front and one towards the rear of the scooter to make sure you have an even load. If I were you, I would lay the straps down onto the floor and extend them out. Make sure the spacing is right for the straps. Then drive the scooter over the straps so it is much easier for you to be able to the wrap the straps around the scooter. Make sure you don't trap any delicate items in the straps, for example mirrors and levers. I don't know if you have thought about it but would there be a possibility of getting a tail lift for your vehicle? That would make it so much easier as all you would have to do is drive the scooter onto the tail lift and then raise it, no need for straps at all then.
I hope this helps and thank you for using FixYa
Posted on Jan 02, 2011
  • Kevin Penn Jan 02, 2011
    I would recommend a thinner ratchet strap, something like the following :-
    I am pretty sure Halfords and other similar retailers sell these sort of straps.
    Hope this helps
How can I tell what year it is?
Hi the year serial numbers r on the frame under the back cover near the motor take the seat of and the cover lifts of only Velcro holding it on....hope this helps
Feb 25, 2016 | Pride Celebrity Xl 4 Wheel Scooter
Where is the reset button.celebrity XL mobility scooter
There is no reset switch. Measure the battery voltage at the charging socket of the scooter, the 2 outside pins.
Aug 27, 2014 | Pride Celebrity Xl 4 Wheel Scooter
Shroud function
It's the red battery cover under the seat. Carefully lift and remove the seat and you'll find that the shroud is simply attached with velcro
Mar 12, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
How do I remove the seat on my Pride Mobility Celebrity X scooter? I have tried lifting up on the seat whilst pulling up on the seat rotation lever and I could not get the seat to release.
Please take care going out the following action: sounds to me like it seized in the tube, with care, lay the scooter at a 45 degree angle, moving your self so you can see where the tube connects to the seat base now stray some WD40 or anything that works on rust etc and leave for a hour , now try wiggle the seat while releasing the seat move catch
Regards
GeWiz....
Nov 03, 2013 | Pride Mobility Products Celebrity X - 3...
Define a mobility service product?
A mobility service product is a device to aid a patient in being able to ambulate in their home. This can include a cane, walker, manual wheel chair or power wheel chair or "scooter". It may also include devices like a lift chair or slide board, as defined by your insurance company.
Oct 09, 2010 | Pride Mobility Products Celebrity XL
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
May 25, 2010 | Pride Mobility Products Celebrity XL
Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Feb 13, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Sep 11, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Replacing motor mounts
It's not as easy as it sounds. Basically you will need to lift the engine off the frame and unbolt the old ones off. I highly doubt that you can do this without disconnecting the transmission. Definitely something that you want an experienced mechanic to help with. It may just not be worth it. If you can lift the engine with the transmission attached (if there is enough room to tilt it up), that would be the best bet but you will need an engine hoist or cherry picker to do this. (THIS IS NOT FOR AN AMATEUR)
Let me know if you have any further questions, this will require a lot of work
Aug 14, 2008 | 1984 Chevrolet Celebrity
Pride Celebrity X 4-Wheel Electric Scooter  Logo
49 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
