I have hp deskjet f2400 series and says (X) cartridge(s) Problem . . at least one of the cartridges has a problem. Click ''Help'' for more information... last time i refill black ink..
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
Evilsmith
  • 26 Answers
SOURCE: hp deskjet 842c blinking ink cartridge light
You have to take off the clear strip of plastic over the copper area, or the printer will not detect it. There should be a green pull-tab on the cartridge.
Posted on May 07, 2008
SOURCE: epson stylus cx9400fax series printer
There is no chip resetter for this model at this time. However, one is to be available in the near future. So for now you must purchase new/refilled cartridges.
Posted on Jan 27, 2009
  • 23 Answers
SOURCE: how to reset lexmark x4580 ink cartridge after refill.please help
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Page 99-100
Posted on Sep 27, 2009
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Posted on Jan 28, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
My HP Photosmart C4700 keeps saying the printer cartridge is in wrong. I have taken them both out and put them in and they are correct.
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
Sep 20, 2010 | HP PS C4780 All in One InkJet Printer
How do i bypass the ink cartridge error on the hp Deskjet F4480? It is saying ink cartridge not compatible but it is a genuine cartridge. And E is displayed on the screen and the light is flashing. How can...
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged - now, these errors can be bypassed on select printer models (temporarily). The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
May 20, 2010 | HP F4480 All-In-One Printer
HOW DO I CLEAN MY PRINTER CARTRIDGES/HEADS?
For using the HP Deskjet 5000 series Printer Assistant:
  1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
  2. Click Utilities .
  3. Click Printer Maintenance .
  4. Click Clean Cartridges .
  5. Follow the on-screen instructions.
read info on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09339&cc=us&lc=en&dlc=en&product=71896
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
402 people viewed this question
k24674
jasbo
jasbo
