Question about Brother HL-2040 Laser Printer
Hi, I own a dcp-145c. The black ink is not printing despite cleaning cartridge and even changing to a new one. What can I do?
  • 164 Answers
SOURCE: My brother printer dcp-165C can't print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
SOURCE: Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Posted on Feb 14, 2010
SOURCE: Brother DCP-145C Print in black and white..?
As far as i know it will not work for color print unless all the cartridges are full. It will still print in b&w- go to properties of your printing document and change to "greystyle" but this will only work if you don't/have not turned off the machine at the power point. Once the machine is reset it wants to confirm all new cartridges and wont allow a black print until they are all in and full. So you cant use cartridges that have run out to "trick it".
I'm not sure if this is the intent of brother ( my guess is yes) a design oversight or a genuine precaution measure for consistency by not letting the printing heads dry out.
The yellow always runs out first, so stock up on them if you do alot of color printing- but the cartridges only last for 6 months so don't go crazy.
Brother if your reading this- Most of us don't care about color~! We just need a printer for uni and information. Make it work on our price range please!
Posted on Mar 07, 2010
SOURCE: dcp 145c brother printer wont print black but
my dcp145 brother printer won't print black , but colour is okay
Posted on Jul 06, 2010
vickyakon11
  • 68 Answers
SOURCE: brother dcp-145c blocked ink jets
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_top.html?reg=eu&c=gb&lang=en&prod=dcp145c_eu_as
from this link u will download the manuals and drivers then i think it will start working................good day sir
Posted on Aug 02, 2010
For my one year old DCP-145C:\r\nThe color of the outprint is red when it shold have been black who is normal for printing text. If all the ink-patrons is in the right place, what do you ting the problem...
if all the ink cartridge is installed at the correct slot, then u can perform this:
menu
mono
up arrow(4x)
7-6-6
mono
that perform deep cleaning. it should be ok after that
Jun 19, 2011 | Brother Office Equipment & Supplies
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
I have installed 4 new cartridges on my dcp 145c printer. black will not print after many cleaning cycles. it was printing before i changed cartridge.
Are you using re-filled or refurbished cartridges instead of new?
If so then the cartridge is probably faulty and needs to be replaced.
Feb 18, 2011 | Office Equipment & Supplies
Brother dcp-145c blocked ink jets
Aug 02, 2010 | Brother Office Equipment & Supplies
Dcp 145c brother printer wont print black but
Apr 12, 2010 | Office Equipment & Supplies
Wont print in black
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Brother DCP-110C All-In-One InkJet Printer
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother MFC640CW
My printer wouldn't print in black even do i change the ink? what should i do!
Aug 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother HL-2040 Laser Printer Logo
264 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
