Can I change Connectify setting to WEP ? I need wifi connection to play NDS games, and I only have usb modem here. So I try to use Connectify, a software to make hotspot with laptop but then NDS doesn't support WPA connection Is there any way to change WPA to WEP in Connectify setting? Thx
On connectify tray icon select Options - "Show all settings" and "Always show Ad Hoc mode". Then you can configure WEP AdHoc
Posted on Apr 01, 2011
How to connect wifi to my wii?
First be sure you have removed the old connections setting from the Wii, then set up the new info In the Wii. That will typically work.
Jul 22, 2014 | Nintendo Wii Console
Ds lite wi fi connect wpa
Try changing your WiFi encription to WEP or no security, this should be available on your cablemodem/router web internface (need a user and password for that) under the Wireless/Security option.
DS Lite is not compatible with any other WiFi encription for online gaming: "Important note about the Nintendo DSi and WPA security: While the Nintendo DSi is compatible with WPA security, Nintendo DS games with online play still require the use of WEP or no security to connect with the Nintendo WFC. Therefore, your connection settings for using these games must be set up on slots 1-3. If you need more details on using your adjusting your router's settings,click here and select your router (if available).
Nov 04, 2013 | 2wire Computers & Internet
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
When I install connectify I lose all internet connectivity, when I uninstall it, I get normal internet connectivity back
This problem is likely being caused by something that Connectify installls called the Connectify Lightweight Filter, which you can find if you right-click on your USB modem connection and select 'properties'. There is a list which says 'Connect using the following items:" and it is in there. Un-check it, and that should work fine, at least it did for me. The bigger question, which I am looking for an answer to, is how to get Connectify to work with my 3G USB dongle, without creating this problem.
Feb 08, 2012 | Connectify
DON'T HAVE SECURITY SUPPORT FOR MY WIFI CONNECTION FOR DSLITE
The problem is the fact the nintendo ds only supports only one security setting which is 128 bit wep. You were probaly trying to connect to a modem with wpa2 or something else. If you want your ds to connect, consult your modem's manual to change the security to 128 Bit WEP and think of a ten character password (no less or it won't work).
Dec 25, 2011 | Nintendo DS Lite Console
My dsi is not connecting to the internet
Hi shamar101,
To set up your wifi on your dsi do the following:
Here's How:
  1. Turn on the Nintendo DSi
  2. Click on the wrench icon to access "System Settings."
  3. Select "Internet" on the third page of System Settings.
  4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
  5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
  6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
  7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
  8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
  9. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Tips:
  1. If you need help with your router settings, visit Nintendo's router FAQ
  2. Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup. Visit Nintendo's manual setup guide if you have a unique situation and need help.
  3. The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
What You Need:
  • A Nintendo DSi
  • A broadband internet connection, such as cable, DSL or FIOS
  • A wireless router
  • A Nintendo Wi-Fi USB Connector (optional)
Hope this helped!
-Luchen
Mar 19, 2011 | Nintendo DSi White Console
What is an ipaddress
hi an ip adress is the numeric adress that your Internet Service Provider gives you that your modem holds in memory. to find yours go to google and type in "MY IP ADRESS"
Feb 11, 2011 | Nintendo DSi XL Burgundy
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
Computers & Internet Logo
9,139 people viewed this question
David Payne
David Payne
