Question about Dell - 0089D Sound Card
My computer is showing problem in device manager code 10 device cant be activated .i dont know which multimedia controller driver is required to be installed i have tried all kinds of sound max from dell support & AC 97 audio controller from CD but it did not work pl help
  • 10,421 Answers
I used my webcam once and now it shows only a black screen what can i do its an MSI U135
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
software if you dont have the driver you will need to download one here are a few you could try although i could not find one for windows 7
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
hope this helps
Aug 22, 2012 | MSI Wind U135-644US Black Intel Atom...
Hitachi hard drive 40gb tells me it cant srart because of a code 10? what is this mean
code 10 no driver is installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click to update driver
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Oct 26, 2011 | Computers & Internet
BOSE SPEAKERS INOP,RCA CABLES PLUGGED INTO DIGITAL OUTPUT OF MY HP PAVILION. TRIED DIFFERENT CABLES.DONT KNOW IF IT DRIVER RELATED.REALTECK DIGITAL OUTPUT SHOWS PLAYING MUSIC BUT NO SOUND JUST HUM
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 25, 2010 | Bose Companion 2 Series II Multimedia...
Sis 7012 driver not wording
Right click on multimedia video controller in device manager and choose update driver, use the internet option, it may take a few minutes to locate and download driver so be patient. hope this helps.
Jan 30, 2010 | Audio Players & Recorders
My computer pentium III dont have sound, when i click the device manager the audio multimedia controler have a question mark with yellow color, please help me to solve this problem , thanks a lot
If it shows a question mark, it means its driver has not been installed.
u need to install the driver for your audio multimedia controller. u may have a driver cd from the manufacturer or u can download the driver from insternet. after that u install it in administrator mode.
Sep 24, 2009 | Computers & Internet
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
Dell Inspiron 710m PC Notebook Problem
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
It sounds like all your software drivers got blown away or can’t load. If that’s the case, try running diagnostics. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 31, 2008 | Dell Inspiron 710m Notebook
I cant open volume control
this problem occurs when your sound driver is corrupted...
prepare the sound/multimedia driver then
go to the the control panel > system > hardware >devices manager
and click on the plus (+) on the Sound, Video and game controller
delete all the items inside this group... then click Action (menu bar) then click Scan for new hardware changes.
Jun 01, 2008 | Computers & Internet
Code 10: Device Cannot Start
Code 10 refers to the operating system not having drivers to talk to the card. Without the drivers running windows cannot run the device.
Mar 08, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Multimedia audio controller
This is a very common problem. You may connect your PC to internet and select update driver. The required Driver will beautomatically downloaded. If you don't get the required material, give me the Model of your Motherboard and the Operating system you are using, I will give you a detailed solution for the problem.
The second thing, you are getting the right memory, rest of your memory has been shared for Graphics.
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Alun Cox
