Question about Miele Washing Machines
Hi: Miele does not seem to give very detailed specs for their Touchtronic W3035 and T8005. Any suggestions? Please respond Thank you!
  • 25 Answers
Sounds like u got suckered into buying an overpriced foreign piece of rubbish in a hard shell. quit sending all your money overseas.just kidding.sorry im relly not much help.
Posted on Jul 09, 2008
Miele Touchtronic W1213 Front Load Washer: The washer keeps adding and then draining water continuously. One time, the cycle ended and the machine continued to add water and drain endlessly....until I...
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
May 17, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this...
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Mar 12, 2011 | Miele Touchtronic G892 Built-in Dishwasher
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
Help ! I own a Miele Touchtronic W1113. I put to0 much Zero liquid soap , using cold water . Now the machine flashes " Fault " for intake and drain . I opened the trap door and let the water drain over...
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
Feb 15, 2010 | Miele Touchtronic W1113 Washing Machine
Trying to find the dimensions of the Miele G694 SC Toughtronic Turbothermic Dishwasher. It doesn't appear to be the standard 24 inch size and wanted to verify the dimensions before I replace it with...
if you go to the Miele website you should be able to download the manual for the machine if you don't have one and in the installation part of the manual this should give you dimensions. if not Miele service dept should be able to help.can't give you tel number as i am not sure where you live. the website will direct you though.
Dec 03, 2009 | Miele 24 in. Touchtronic G694SC Built-In...
Smoke in drum on spin cycle
I did it by going to an agent, I do not trust you,,,how do I know that your services are for real? Please do not be offended.
Dec 10, 2008 | Miele Touchtronic W1113 Washing Machine
Drain Hose Replacement
drain hoses are quite standard. the rubber spigot at each end can be different sizes and some have a right angle bend at the end. suggest you take out the old hose and take it along to match up - easiest way
Aug 28, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Drsining washer manually
open the little door at the bottom fron and twist open the lint filter clean out
Jul 12, 2008 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
60 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
