Question about Kenmore 15129 Built-in Dishwasher
Water doesn't drain
The motor runs and you can here the water trying to drain but it is not draining into the garbage disposal.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 29, 2010
Tip
Garbage Disposal Leak from bottom of motor
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
on Sep 23, 2010 | Kitchen Appliances - Others
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My dishwaher wont drain
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 16, 2010 | GE GSD2200G Built-in Dishwasher
Wont drain
Jun 19, 2010 | Maytag PDB4600 Built-in Dishwasher
Wont drain
Apr 28, 2010 | Bosch SHU5316UC Dishwasher
Used reset button, the motor runs but the blades are not turning?
sound's like you have a problem with your drain pipe's. it is not normal for water to come back up.check the allen key bolt, located on the bottom of unit .insert allen wrench /key,and turn in a clock wise&counter clockwise motion to see if disposal is jammed.you also might consider some drain opener before it get's worse
Apr 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Wont drain completely
Apr 13, 2010 | GE Nautilus 24" Built-in Dishwasher
Water wont drain from dishwasher
Dec 26, 2009 | Magic Chef CDB6100 Built-in Dishwasher
Kenmore 15129 Built-in Dishwasher Logo
53 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
