Question about Hitachi 50SBX70B 50" Rear Projection Television
Upper left corner of screen red 3d blue wave
Got tv for free rest of screen awesome pic willing to invest since its free whats problem how much to fix, can i do alone any detail instructions
  • Hitachi Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
upper left corner of screen red 3d blue wave - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Can not get the focus grid to line up correct green adjusts fine but blue upper left corner will not adjust and the red grid is way off and will not fix
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 08, 2011 | Samsung HC-P4752W 47" Rear Projection...
I have a Hitachi and the red in the upper corner is drooping
  • Screen looks 3D
69189a5.pngSOLUTION
May 03, 2011 | Hitachi Televison & Video
Color fade upper left hand corner, looks like I need 3d glasses on the edges of everything
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 13, 2011 | Hitachi 50UX58B 50" Rear Projection...
Upper corner of picture looks like 3D. picture on upper corner looks like it is off vertical with this happening. What do you do to fix this Hitachi 57F500 model?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 21, 2011 | Hitachi 57F500 57" Rear Projection...
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | Samsung PCL541R 54" Rear Projection...
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 06, 2011 | Hitachi 50SBX78B 50" Rear Projection...
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Jensen t.v model ts2750j blue screen red lock upper left
My Advent TV did the same thing. Blue Screen with a red lock in the upper left corner. Just press and hold the display button for about 10 seconds. It will clearn
Feb 02, 2009 | Jensen TS2750J TV
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
