Question about C3RS730 LCD
I need to make my alarm more sensitive - C3RS730 LCD
    New Friend:
  • 103 Answers
You will need to access the inpact sensor. It has an adjustment knob on it.
Posted on Jan 12, 2011
Alarm goes off when unlocked and undisturbed why?
Jeff, maybe sensitivity can be adjusted, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Adjust Car Alarm eHow
2008 Toyota Tacoma Alarm too sensitive
Thread How to adjust the sensitivity of car alarm
http://www.driveaccord.net/forums/51-8th-generation/60017-oem-alarm-sensitivity-setting.html
Mar 23, 2016 | Cars & Trucks
MY CAR ALARM KEEPS GOING OFF FOR NO REASON
Your car alarm has a sensitivity setting if the sensitivity is too high it will set off the alarm if the wind blows too hard or a heavy vehicle drives by in close proximity turning down the sensitivity will solve this problem
Nov 18, 2015 | Cars & Trucks
Alarm going off when batery is conected
sounds like the alarm is to sensitive most alarms will have a sensitivity adjustment on the module ,you may need to adjust it ,the adjustment is a screw to suit a blade screw driver.regards agwbk.
Feb 05, 2011 | Yamaha FZ6 Fazer Motorcycles
Can the sensitivity for the alarm system be adjusted
no, there are no adjustments.. if the alarm has an issue then a code should be stored. You will need to retreive it to begin with.
Jun 11, 2010 | 1999 Oldsmobile Alero
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Alarm sounds for no reason
sensitivity adjustment on alarm module needs adjusting to desired sensitivity
Jul 04, 2009 | 2002 Volkswagen Beetle Turbo S
Continuosly alarm going off.
If its an aftermarket alarm check the manual to adjust the sensor sensitivity. If you don't have the manual check the alarm's manufacture website or contact them. Some times the shock sensor is in the antenna itself. There'll be a button saying something like, HI, MID, LOW. Set the sensitivity to MID or medium sensitivity.
May 06, 2009 | 1998 Acura CL
Make car alarm more sensitive
Locate the shock sensor. Using a small screwdriver you can adjust the sensitivity of the sensor. Move srew in only 1/4 turns as this will make big adjustments. Adjustments may make alarm too sensitive so try it out and see what works for you.
Apr 04, 2009 | Vehicle Parts & Accessories
Can i make my k-9 classic car alarm more sensitive
You will need to purchase an accesory which will allow you to add more shock sensors. You can install one in the trunk in order to make it more sensitive.
Van Alarm keeps going off during the night, for no reason!
yes, the sensitivity can be adjusted. is it a factory alarm or did you have it put in? Ford's have a tendency to cross wiring causing alarm to go off every hr or every 2hrs it will be consistent. next time time it.
Mar 17, 2009 | Code-Alarm Code Alarm Transponder
C3RS730 LCD Logo
222 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Charles Osborn
handt729
Level 1 Expert
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
