My usb not working - Computers & Internet
Maybe you might have a shorten in your cord or its not showing the small indicator at the bottom right of your computer
try unpluging and plug it up to a different usb port and it might show the problem
Posted on Jan 03, 2011
Samsung r519 usb ic
All USB not working? If not remove USB device re-boot and then re insert USB device. Still does not work check Device Manager look for any errors under the USB list. That said, how old is your Samsung and what are you using in your USB port?
Oct 29, 2012 | Samsung R519-53S Notebook
Usb header not working
Usb ports are bogus. You can always install a pci usb card though. Beats replacing the mo bo since you have already tried everything else to no avail.
Apr 15, 2017 | ASUS M2N-MX SE Motherboard
Usb damage
If all the USB ports fail to function, then repairing them is difficult, as the problem will be with the USB controller on the motherboard. If one or two fail to work, but the other ones work, then you have the option of putting a USB extension port into the working USB socket and that will allow you to run several devices from the one port, or, depending on the laptop in question, you can get a USB adaptor PCIMCIA card or Cardbus card that will plug into the expansion slot on the laptop and will give you a more permanent USB solution.
For this to work, there must be at least ONE working USB port
Jul 21, 2011 | Computers & Internet
Window7 crache connecting usb fax modem
I expect it is a problem with your USB Driver, Get an updated driver for your USB slots. (either from motherboard manufacturer or USB manufacturer if it is a USB "card")
Even default or old drivers might work Try a few different USB drivers - a new one, the reccomended one, the original one...
(good idea is to use a ps/2 mouse and keyboard since your usb will be going on and off while you're working, it can be hard to click YES when you're keyboard AND mouse aren't working ;-)
if it still dont work...
Can you set any of your USB slots to work in USB 1.0 instead of 2.0, there could be an option in bios, maybe it will run the "OLD" modem in an OLD mode?
Jan 21, 2010 | Computers & Internet
Usb mouse
here is what you can try,
1. try to connect the usb mouse in the other usb ports to check if it works
2. try another usb mouse.
if the usb mouse works in other ports and not in some of them...USB ports gone bad.
if it does not work anywhere, the mouse has gone bad. also to check the usb ports check if keybaord works or not. if yes..its just the mouse. it cost approximately $10. go and get a new one.
Sep 21, 2009 | Computers & Internet
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Usb problems
Have you checked that they are correctly wired or jumper set on The System Motherboard.
Mike @ compurepair.
Apr 19, 2008 | Intel D102GGC2 Motherboard
Usb ports not picking up memory stick
Is it just Memory Stick, or everything that you plug into USB?
Try following:
  1. plug in other USB device into ports
  2. if it does not detect any USB device on any port on your computer
  3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
  4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
  5. If just back USB do not work than they are dead>
Jan 30, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
