Question about Samsung Refrigerators
Refer.RT32 Y8MS/ ZBSS /Z8PS NOT WORKING - Samsung Refrigerators
4x4 4.0l V6. What are the probable causes of DTCs P0112, P0117, P0122, P0513, P0556, and P0565?
code p 0112 refers to intake air temp (IAT) sensor --circuit malfunction===cause --wiring short to graound--wiring short to positive --IAT sensor ---ECM
code p 0117 refers to engine coolant temp (ECT) sensor--circuit malfunction=== causes --coolant thermostat---wiring short to ground--wiring short to positive ---ECT sensor
code p 0122 refers to throttle position (TP) sensor A/ accelerator pedal position (APP) sensor A low input === causes wiring short to ground--TP/APP sensor --ECM
There are 3 responses to p 0122 and all refer to TP switch /sensor plus wiring open /short to ground/ short to positive
code p 0513 refers to incorrect immobilizer key=== causes immobilizer system
code p 0556 refers to brake booster pressure sensor---circuit range / performance=== causes --wiring---poor connection---brake booster pressure sensor---ECM
code p 0565 refers to cruise control master switch. off signal --malfunction === causes wiring---cruise control master switch--ECM
by reading all the codes you will see that common causes are wiring problems and ECM so may be a quick check would be to replace the ECM with a known working unit first and work back from there
Feb 23, 2016 | 1994 Ford Ranger Supercab
My samsung rt32/2009 freezing all over why is it, how can i defrost my fridge only on freezer
Sorry but when you turn the freezer off the frig is also off .not separate units
Sep 23, 2015 | Samsung Refrigerators
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
2001 Lincoln towncar signature....PROBLEM:power door locks-trunk release-driver side power seat-keyless outer door entry-radio&clock......when weather is hot, door locks-trunk release-power seat-keyless...
What mechanics ? No codes stored in driver door module or power seat module ? Or don't these mechanics know about that ?
Did you try the dealer ?
Diagnostic Trouble Code (DTC) Chart DTC Description Source Action B1201 Fuel Sender Circuit Failure HEC Module REFER to Section 413-01 . B1204 Fuel Sender Circuit Short to Ground HEC Module REFER to Section 413-01 . B1205 Failure (Open or Short to Battery) HEC Module REFER to Section 413-08 . B1208 HEC Switch-1 Assembly Circuit Short to Ground HEC Module REFER to Section 413-08 . B1213 PATS Number of Programmed Keys is Below Minimum HEC Module REFER to Section 419-01 . B1231 Longitudinal Acceleration Threshold Exceeded RCM REFER to Section 501-20B . B1232 PATS Bad Diagnostic Byte Received HEC Module REFER to Section 419-01 . B1249 Blend Door Failure EATC Module REFER to Section 412-00 . B1251 Climate Control Air Temperature Internal Sensor Circuit Open EATC Module REFER to Section 412-00 . B1253 Climate Control Air Temperature Internal Sensor Circuit Short to Ground EATC Module REFER to Section 412-00 . B1255 Climate Control Air Temperature External Sensor Circuit Short to Battery EATC Module REFER to Section 412-00 . B1257 Climate Control Air Temperature External Sensor Circuit Short to Ground EATC Module REFER to Section 412-00 . B1261 Climate Control Solar Radiation Sensor Circuit Short to Ground EATC Module REFER to Section 412-00 . B1312 Headlamp Input Circuit Short to Battery LCM REFER to Section 417-01 . B1317 Battery Voltage High HEC Module REFER to Section 414-00 . B1317 Battery Voltage High RCM REFER to Section 414-00 . B1317 Battery Voltage High Air Suspension Module REFER to Section 204-05 . B1318 Battery Voltage Low HEC Module REFER to Section 414-00 . B1318 Low Ignition Voltage During Speed Control Operation NGSC Module REFER to Section 310-03 . B1318 Battery Voltage Low Air Suspension Module REFER to Section 204-05 . B1318 Battery Voltage Low RCM REFER to Section 414-00 . B1322 Door Ajar LF Short to Ground DDM REFER to Section 501-14B . B1334 Decklid Ajar Rear Door Circuit Short to Ground LCM REFER to Section 501-14B . B1340 Chime Input Request Circuit Short to Ground LCM REFER to Section 501-20B . B1342 ECU is Defective ABS Module CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ABS Module. REFER to Section 206-09 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective ACM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ACM. REFER to Section 415-01 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective CPM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new CPM. REFER to Section 419-08 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective DDM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new DDM. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective DSM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new DSM. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective HEC Module CLEAR and DOCUMENT the DTCs. PERFORM the HEC self-test. If DTC B1342 is retrieved, INSTALL a new HEC Module. REFER to Section 413-01 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective LCM CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new LCM. REFER to Module-Lighting Control (LCM) in this section. CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective NGSC Module CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new NGSC Module. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective Air Suspension Module CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new air suspension module. REFER to Module-Air Suspension in this section. CLEAR the DTCs. REPEAT the self-test. B1342 ECU is Defective RCM REFER to Section 501-20B . B1352 Ignition Key-In Circuit Failure LCM REFER to Section 413-09 . B1359 Ignition RUN/ACCY Circuit Failure LCM REFER to Section 211-05 . B1396 Power Door Lock Circuit Short to Battery DDM REFER to Section 501-14B . B1397 Power Door Unlock Circuit Short to Battery DDM REFER to Section 501-14B . B1402 Driver Power Window Down Circuit Failure DDM REFER to Section 501-11 . B1445 Door Handle Circuit Short to Ground DDM REFER to Section 501-14B . B1446 Wiper PARK Sense Circuit Failure LCM REFER to Section 501-16 . B1484 Brake Pedal Input Open Circuit ABS Module REFER to Section 206-09 . B1485 Brake Pedal Input Circuit Short to Battery LCM REFER to Section 417-01 . B1526 Keyless Entry Circuit Short to Ground DDM REFER to Section 501-14B . B1529 Memory Set Switch Circuit Short to Battery DDM REFER to Section 501-09 . B1533 Memory Position No. 1 Switch Circuit Short to Battery DDM REFER to Section 501-09 . B1537 Memory Position No. 2 Switch Circuit Short to Battery DDM REFER to Section 501-09 . B1545 Seat Direction Switch Assembly Circuit Short to Battery DDM REFER to Section 501-10 . B1549 Power Window Master Circuit Short to Battery DDM REFER to Section 501-11 . B1553 Decklid Release Circuit Short To Battery DDM REFER to Section 501-14B . B1555 RUN/START Input Circuit Failure LCM REFER to Section 211-05 . B1556 RF, LR, RR Door Ajar Circuits Short to Ground DDM REFER to Section 501-14B . B1569 Headlamp High Beam Circuit Short to Battery LCM REFER to Section 417-01 . B1577 Parking Lamp Input Short to Battery LCM REFER to Section 417-01 . B1581 Panel Dim Increase Input Circuit Short to Battery LCM REFER to Section 413-00 . B1585 Panel Dim Decrease Input Circuit Short to Ground LCM REFER to Section 413-00 . B1600 PATS Key Problem - No Key Code HEC Module REFER to Section 419-01 . B1601 PATS Received Non-Programmed Key Code HEC Module REFER to Section 419-01 . B1602 PATS Received Invalid Key Code Format HEC Module REFER to Section 419-01 . B1663 Driver Seat Front Up/Down Motor Stalled DSM REFER to Section 501-10 . B1664 Driver Seat Rear Up/Down Motor Stalled DSM REFER to Section 501-10 . B1665 Driver Seat Forward Backward Motor Stalled DSM REFER to Section 501-10 . B1666 Driver Seat Fwd/Bwd Recline Motor Stalled DSM REFER to Section 501-10 .
Also do there know anything about serial data bus ?
Plus , do they know what voltage drop testing a electrical circuit is . I should find better mechanics .
May 31, 2017 | Cars & Trucks
Hi I would like to know when buy n refer is going to sell electronic goods.
Unfortunately Buy n refer works in a non-periodical system, so you can't say what they are selling next
Jun 17, 2011 | Buy N Refer
I have the sims 2 fun with pets collection, i got it from a friend and they dont have the serial key for it,is there anything i can do besides buy another game?
Try these codes:-
CK9R-PTSP-YWUM-XBHG-7J9Z
or
DWJ2-Q92Z-R1R1-5F6R-077P
or
THA2-Z3FK-OR1A-3HZ4-2WUS
or
374U-U5GT-1RZ9-4PDG-T5QZ
or
DKSS-YCA2-ZO11-SSP7-3AFH
or
XUT3-6LHW-ZOR1-JH7N-VV7I
If none of these works, Try asking the company that produces the game, as well as providing a receipt and some other form of proof of purchase.
or
Go to the place where you bought the cd and ask for the registration code.
Good Luck and have a nice day.
Jun 05, 2010 | EA - Electronic Arts Sims: Complete...
Windows won't roll up and down and wipers stopped working at the same time. The blinkers stopped shortly at the same time but they are working again. We thought it was a fuse problem but the fuses seem to...
Do you know anything about automotive electronics ? The GEM - generic electronic control module is in charge of turning on the wipers an control the power windows . Would think this a fuse problem . Computer problem maybe , the first step in diagnosing a problem like this would be to hook up a factory or professional scanner an checking for DTC'S - diagnostic trouble codes . Don't think about replacing the GEM module ,if you don't know how to test it's electrical circuits an check for codes . Can set a number of codes !
B1431 Front Wiper RUN/PARK Relay Coil Circuit Failure GEM REFER to Section 501-16 . B1432 Front Wiper RUN/PARK Relay Coil Circuit Short to Battery GEM REFER to Section 501-16 . B1434 Front Wiper HI/LO Speed Relay Coil Circuit Failure GEM REFER to Section 501-16 . B1436 Front Wiper HI/LO Speed Relay Coil Circuit Short to Battery GEM REFER to Section 501-16 . B1438 Front Wiper Mode Select Switch Circuit Failure GEM REFER to Section 501-16 . B1441 Front Wiper Mode Select Switch Circuit Short to Ground GEM REFER to Section 501-16 . B1446 Front Wiper Motor PARK Sense Circuit Failure GEM REFER to Section 501-16 . B1450 Wiper Wash/Delay Switch Circuit Failure GEM REFER to Section 501-16 . B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM REFER to Section 501-16 . B1458 Washer Pump Motor Relay Coil Circuit Failure GEM REFER to Section 501-16 . B1460 Washer Pump Motor Relay Coil Circuit Short to Battery GEM REFER to Section 501-16 . B1462 Seat Belt Switch Circuit Open or Seat Belt Buckled GEM REFER to Section 413-09 . B1466 Wiper HI/LO Speed Not Switching GEM REFER to Section 501-16 . B1473 Wiper LO Speed Circuit Motor Failure (Wiper Energized and Park Sense Not Seen) GEM REFER to Section 501-16 . B1476 Wiper HI Speed Circuit Motor Failure (Wiper Energized and Park Sense Not Seen) GEM REFER to Section 501-16 . If you don't know any of this , your best bet take it to a qualified repair shop.
Feb 26, 2018 | 1997 Ford F150 Regular Cab
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Circular reference working how to open excel file
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Nov 20, 2008 | Microsoft Excel for PC
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
