Question about Quasar SP-3220 32" TV
My philip tv av picture lose, - Quasar SP-3220 32" TV
How to format the picture to fit the screen with a universal remote (the one we have is not a philips remote)
Hi there. It is a common problem with replacement remotes. Some features like the one you describe will not be available in this one.
A Philips replacement remote is the solution. Best of luck.
Apr 19, 2014 | JVC AV-32020 32" TV
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
2 Problems
1st problem-reduce the supply voltage on the power supply to the recommended 95v.if prob does not clear change suspect capacitors around the line output transformer. 2nd problem-check;continuity of av-cables ;dry joints on av inlet sockets of the tv card.
Aug 24, 2007 | Philips Magnavox 27MS343S 27" TV
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Televison & Video Logo
22 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
