Question about Logitech Webcam
My webcam is showing hedgy picture, i am appearing like a ghost
Screen ghost actions and loss of picture
If the digitizer is anything like an LCD screen it's probably the inverter more than anything. These will sometimes "light up" for only a second or so, then go dim as they lose the voltage needed to run the backlight. The ghosting may be the ambient light reflecting through the glass when the backlight goes off. Just a guess, but if there is an inverter it may need to be replaced.
Feb 21, 2014 | Computers & Internet
Fuzzy picture when using dell camara
Not all webcams are great quality, and can appear fuzzy, especially in low light. Was the webcam previously producing a better image?
Jan 30, 2014 | Dell Inspiron N5030 Notebook PC
My t.v. picture was coming i ghost shade why?
If you are using antennae check the direction. If this is a cable input , then with a DVD , if all these show a ghost image, then the convergence of the TV section must be checked. Possible fault in the picture processing -( Y amp luminance)can lead to ghost images.
Jan 29, 2011 | Televison & Video
We have an Hiatchi UltraVision Model# 53SWX10B that the sounds comes on initially then 30 seconds later goes mute. The picture is still great but since it's 8 years old is it worth repairing. What could be...
Hi , audio output failure, possibly needs re-boot of cable/sat system, too many variables to troubleshoot on here, and thats generally a great tv so yes I would advise you to get a tech to fix it, video-tek
Jul 01, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Movement causes bluriness
I have a expensive webcam as my main one and a cheap webcam as my less used one and my cheap one does exactly the same thing
It is called Ghosting and there is nothing that can be done about it, it is just a poor quility webcam
Dec 26, 2008 | Logitech QuickCam Connect Webcam
Plasma has flickering, ghostly picture
Repair man tells me its a high voltage circuit board but i dont know what the board looks like so i can replace it maybe this help let me know if you find out anymore.
Dec 26, 2008 | Televison & Video
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Logitech webcam
in my view the hardware ciruit (IC) may develop heat that make this problem, change IC
Dec 26, 2007 | Logitech Webcam
Logitech Webcam Logo
19 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
