When i press the switch to start up the blue hard drive light comes on but not the yellow power light, it will not boot up and after a few seconds the blue light goes off and the no signal sign comes on, I have had a new powerpack fitted i year ago,any ideas ? Frank
  • Computers & ... Master
  • 1,572 Answers
Strip the system down to the absolute minimum: unplug all of the drives, disconnect the speakers and any USB devices, and remove all but one memory module. If the system starts (of course it won't boot), one of the items you removed is defective. Add the parts back one at a time until you have a failure.
If it still doesn't start after the strip-down, swap the remaining memory module with another one. If that doesn't do it, try putting a video card in and using that instead of the on-board video (you have provided no details about your hardware, so I'm guessing at your configuration).
Caution: shut down the computer and unplug it before adding or removing any internal parts to avoid damage to the motherboard or parts (every time you add back a part). Do not touch any circuitry with your fingers; handle memory modules only by the edges. Failure to observe this precaution may cause electrostatic discharge damage to the parts (even if you don't feel the shock when you touch it). You can reduce the chance of damage by making sure you have bare skin touching the metal case of the computer while you work on it. It is not necessary to turn off the computer to plug in speakers or USB devices or remove them.
If the system will not start when it is stripped-down, either the power supply or the motherboard is bad.
Posted on Jan 02, 2011
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
PS3 yellow lights won't turn on
You may have the yellow light of death. You get the yellow light of death when the playstation stays on too long or alot of use or it may taken some damage.
May 09, 2013 | Sony Playstation 3 (PS3) Console
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Feb 19, 2011 | HP Compaq Presario F756NR Notebook
On my laptop i have a problem with the blue screen. When I turn my laptop on it loads for a few seconds then it gives me the blue screen, what do i do?
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
hope this helps
Oct 24, 2010 | Computers & Internet
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
Computer will not reboot, I have power, when I press the switch I get a yellow light under the hard disk indicator and the E-switch will not turn blue, stay off all the time. I have the impression that I...
Test your motherboard first - unplug everything (except at least some of the RAM) and see if it boots up. You should at least get a beeping sound.
If that works, check the RAM piece by piece - you can find a free program called MemTest (or Memtest86) online with will run from the boot menu, so it will execute and test all your RAM chips before the hard drive even starts up. If that all checks out fine, add in graphics card, hard drive, etc until you find the component which breaks it.
Mar 09, 2010 | Computers & Internet
Laptop will not switch on
Shut down the system, disconnect every thing you can possibly disconnect and remove the battery.
Press and hold the power button for 15 seconds. Reconnect A/C power and try to boot up.
If no change, remove the CD/DVD drive and if you feel comfortable, the hard drive. Reconnect power and try to turn on again.
If you still get nothing, check for any loose screws on the bottom of the case and snug them (DO NOT OVER TIGHTEN). Just finger tight so the screw is not turning loosely. Remove and reseat the RAM. If you get no power, remove the RAM and reconnect power to see if you get beeps from the system.
Let me know if you need to go further than this.
Honest1abe
Jan 17, 2009 | Computers & Internet
Unit will not Boot up
Make sure your monitor is plugged in and try again
Jul 07, 2008 | E-Machines eMachines Desktop PC
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
