Question about Karcher 2500 PSI Pressure Washer
Pressure problem HI, I have very little pressure at the gun end. I have pleanty of water to supply the machine. When I release the trigger it kicks back and forth.
  • csaenz08 Jul 09, 2008
    hi, let me tell you the reason why I think this happened. I was using the pressure washer were there was little quantity of water for it and is would only get pressure when there was sufficent water. I still used it like this cause I had to pressure wash this area. So I took the pump apart and looked at the karcher web site and it helped me put it back together. This did not help. At this time it was just getting pressure on and off with the trigger on. I read some of the trouble shooting online and so I did what it said. I took the two torx screws off and took that valve out and greased it. With this it got about a quarter of the total pressure but now it is constant. Now when you release the trigger it seems as if the pressure goes on and off and it does not stop doing this. If you can do me the favor of telling me exactly what number in the diagram in the web site you gave me is the part you are referering to. My pressure washer is the G 2500 VH. There are many valves that don't say which is the pressure valve. Thank you for your time and for your help.
  • Anonymous Mar 22, 2014
    the lance keeps sprayjng as the trigger on gun does not shut off water supply
  • 33 Answers
Sorry i am not the one who gave you info from before. but from what you say your problem is water supply. if you don;t have enough to feed the pump it will cavatate. and that is why it surges the way it does.
Posted on Apr 21, 2009
    Champion:
  • 313 Answers
I think the problem is the pressure release valve.see www.pressureparts.com for the above model.this the web for karcher washer.
Posted on Jul 09, 2008
  • mr aicnelav Jul 10, 2008
    many pressure washer manufacturer uses different type of pump & names on the parts. i look the model piston side 2 items.
    1 & 8. remember to bleed the air out first before running the pump may co'z problem too.
    thanx
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
Motor is working but does not spraying the water and also cant remove main hose from both machine and trigger gun. what is the problem?
Hi Fahad:
I could be suspicious that the gun may be clogged.
If the hose and gun are pressurized the couplings should not be able to be dis-connected. The pressure should be released first by shutting the motor off and then squeezing the trigger to allow the water to drain.
May I suggest that you first try a different nozzle on the gun, and if it still won't work, a "dismantle and service" procedure would be the next step.
Mar 13, 2016 | Garden
I get hose pressure from my Brute 2600 psi, 6.75hp power washer when the engine is not running, but when I start the engine, I get no additional motor pressure.
The pressure you have when the motor is not running is supply pressure through the unit. When you start the motor it will build up pressure then shut the pump action down until you pull the trigger of the gun. When you release the trigger the pressure drops to zero . This happens through a relief valve that the pressure hose is connected to. If what I stated is not happening then there is a problem with insufficient water supply to the machine or a problem in the relief valve.
Sep 28, 2013 | Yamaha Kawasaki Genuine Kvf750 Brute Force...
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Cant start the unit ,there is to much pressure on the pull chord when water is hooked up.
Trying to start a pressure washer with water supply on and gun trigger off will be a difficult task. It could be comparred to trying to start a lawn mower with the mower in tall grass. Place the mower on the drive or walkway and pulling the rope to start the engine is much easier. It is easy to start your pressure washer with no water in the system however there is a remote possibility that you could overheat the seals if you take too long to turn on the water. It is a little more difficult to start the washer with water supply on and someone holding the trigger to wand open. This will prevents pressure from building and making engine hard to start. You will not damage your washer if you start it with water supply off if you flood the pump and pressure hose with water first . Here is the procedure I use if i am working alone. I trun on the water to pump and open trigger to gun to allow water to flow into pump and pressure hose. Turn off water (leaving the water supply on will make it a little harder to pull starter). Start engine while holding trigger to gun open. When engine starts release gun causing unloader to activate circulating water in pump. Now turn on water and you are ready to work. If your system is under warranty however, I would advise to use the starting procedure outlined by mfg (hold open trigger to gun however). To get the longest life from unit try using it at say 75% of capacity or lower if your can and use max pressure on the tuffest jobs. Leaving your washer at full pressure for all jobs is like driving your car at 100 mph everywhere your go. Good luck.
Aug 24, 2010 | Northstar Professional Series Pressure...
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
No pressure
It is probably air locked....Here's what you need to do. Connect the garden hose, and HP hose, but not the gun. Turn on the water, and let it run while you make sure that there are no high points in the garden hose that can trap air....Work the hose so that any air is displaced through the pressure washer. Continue in this manner through the HP hose. Shut off the water and connect the gun. Turn the hose back on, and operate the gun for several minutes, pulling the trigger and releasing. This alternately allows the water pressure to build up on house pressure and then to depressure, pulling residual air from the system. Release the trigger, and start the machine. Usually, this is enough to get full washing pressure. If it is very difficult to start, you can hold the trigger down on the gun and pull the start cord at the same time. Holding the trigger down acts as an unloader, making the starting easier.
Hope that this helps, --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
271 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
