Question about Microsoft Windows XP Home Edition
Hard Drive on Gateway laptop turns off by itself…
So i've had this laptop for about 1.5 years and it just started doing this. I would work on it and all of a sudden the HDD would just turn off. I would be like Double U Tee Eff and then it would start back up again. It was fine and dandy. Not the perfect experience, but it was working. Well after a couple times of doing that it started doing it and then not restarting at all. I thought it could've been a virus, since my friend's laptop developed the same symptoms at about the same time, but i couldn't explain how a virus will work like that even outside of windows... it would not let the HDD start up even at the bios level :( Give me some leads pleeze rathersmart is offline Reply With Quote my computer started malfunctioning about a week ago i don't know what happened but in that same time frame my Norton 360 subscription finished and i had no more protection . At first when i turned it on it would load but nothing would show on the screen and the keyboard and mouse didn't work then one time it it just miraculously started loaded then i saw the screen load to BIOS then it wouldn't load past BIOS then i stopped seeing the screen again then it worked i was soo happy cause it loaded al the way to the log in screen then it shut down. so i started moving faster this time i logged in then it just shutdown after 4 mins or so i need help please anyone helpme please ~.:Djsmog:.~ mail me at d_smog@yahoo.ca
  • d_smog Jul 17, 2008
    yhea thats kinda what i did buut with out ur help i wouldnt have figured our what to do it was the hard drive and the fan thingy that covers the intel card it was placed well and the hard had a problem so my uncle just reformated the the drive and we got a new fan and dat was it what u were saying wouldve worked if the fan wasnt broken thnx so much
    Novelist:
    Scholar:
  • 158 Answers
Get the avgantivrus program and run this is a free version download vis pc and transfer the exe to the laptop and run to install run it as soon as you can then you might be able to save all files out using safemode once all files are removed use your installation cd or recovery cd and re-do operating system from scratch.
best of luck
Posted on Jul 09, 2008
When i turn on the latop it says gateway and also says repairing pc and it wont go any further
try turning on your laptop in safe mode with command prompt by hitting f8 on startup,
try to check your your hard drive on typing "chkdsk" command. it will show the status of your hard drive. if it doesnt work theres problem with your hard drive
Apr 27, 2016 | Gateway Computers & Internet
How to turn on a NV5378u gateway laptop
1. Charge the battery for 2 hours,
2. Press the power button.
If the laptop does not start, you can do this:
Please use the VGA port (VGA external monitor), also please do these:
1. Unplug the AC adapter,
2. Remove the battery,
3. Remove the hard drive,
4. Press the power button and hold it for 15 seconds,
5. Plug in the AC adapter,
Restart the laptop.
If the problem persist,
Note: Do not insert the battery, and do not install the hard drive.
2. Reseat the memory (remove it and reinstall it),
3. Plug in the AC adapter,
Restart the laptop.
If those actions do not solve the problem, then your GPU/motherboard is dying.
Mar 09, 2014 | Gateway NV5378u Notebook
Blank screen on laptop
Please test it:
1. Remove the hard drive and turn on the laptop. If the laptop display BIOS, then replace the hard drive with a good working hard drive,
If it the laptop screen does not display anything, then:
2. Test it using an external monitor.
- If the external monitor blank too, then there is something wrong with your laptop's GPU and or motherboard (you need to replace the motherboard)
Mar 05, 2014 | Gateway NV59C09U NV52 NV53 ......
How to retrieve files from a hardrive on laptop that will not work
One way to do it would be first remove the hard drive:
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52faq4.shtml
Then use a hard drive dock such as this one (http://www.newegg.com/Product/Product.aspx?Item=N82E16817153071) to connect via USB to a working computer where you'll be able to access your files.
Jan 13, 2012 | Computers & Internet
I ve an acer aspire 5742...as soon as i connect my internet the laptop gets switch off within 30 mins.....it continous to switch on and off...pls suggest me wat to do
Hi
is it the laptop itself switching off or is it the hard drive turning itself off after
30 mins because by default many laptops are set to turn off the hard drive after 30 mins
also by default the display turns off as well after a short time
these setting can be adjusted in control panel power options
Apr 14, 2011 | Computers & Internet
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
I have a gateway 6010GZ laptop it turns on and the cd drive spinns but thats it
turn on the power , tapping delete to bring up the BIOS
on the
main page look to see if the hard drive is being
detected everything that is in the computer ( main comp-
onents ) can be seen in the BIOS goto the boot tab make
sure the detected HDD is
booting up first not the optical drive , when finished press
F10 hit yes to save and see if the computer will boot up
I have 4 Gateway notebook computer , they are very good notebooks however they are notebooks and notebooks are
prone to needing repair tweaks constantly every once in
awhile the sound just stops working like if you switch from headphones to speakers , all Gateway notebooks come with
a reinstall drivers utility , Goto start/programs/gateway recovery center from that utility you can reinstall drivers programs and
many other default setups . there is only 3 things that can make
a computer not turn on 1. the hard drive 2. the video card 3. the
RAM , in BIOS you will see which one of these components are
not working .
Feb 11, 2010 | Gateway Computers & Internet
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Gateway solo 2500
Here is a picture of the hard drive caddy itself. http://cgi.ebay.com/NEW-GATEWAY-SOLO-2500-LAPTOP-HARD-DRIVE-CADDY-ADEAL_W0QQitemZ6863173195QQcmdZViewItem
You see that hole in it towards the front?. If you look underneath the laptop you should see a tray that looks like that with a screw in it. Just take the screw out and the whole caddy should slide right out.
Mar 01, 2008 | Gateway Solo2300 200MMX Pentium, 200 MHz...
Microsoft Windows XP Home Edition Logo
102 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
