Question about Garden
Mower is making a clunking noise when attempting to start and once running. blades seem quite loose.
    Novelist:
  • 144 Answers
I think that noise is because your blades are loose. They should be tightened right away because they could come off when you are using it with the possibility of injury to somebody. I have serviced some mowers with that problem. They make more noise when starting because they are turning slow and moving around more than when turning at high speed. Best regards and good luck.
Posted on Jan 02, 2011
Cub cadet riding mower blade will not engage
be sure battery is fully charged, check the switch and clutch.
Jul 07, 2017 | Cub Cadet Garden
My masport mulching lawnmower making a clunking sounds when it's going
Blades could be hitting dead grass under mower deck,or the blade is loose !
Feb 22, 2015 | Garden
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
Noisy mower blades
Hi make sure the blades are not hitting each other, also check the blades for marks or paint missing to help you find the contact area. Regards Phil.
Jun 12, 2012 | John Deere Garden
When starting my mower the starter makes clunking noise
Something broken in starter. Remove and check or have shop check it.
May 14, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
I was mowing the lawn, and I ran over a dirt *****. Now the engine will not start. It also sounds like something is loose inside. I hear a few clunking sounds when I pull the cord. Do I need to take...
Yoy can try tightening the blade bolt. i know it sounds funny but if the blade bolt is loose (or even alittle loose) the blade balance throws off the engine balance and can cause it to
1 not start
2 make loud clunking noises when trying to start
3 make a real racket if it does start
try flipping the lawn mower over and just tighten the bolt that holds the blade in place.
That should fix your problem.
Please dont forget to rate my answers
Thank you
Jun 17, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
My Cub Cadet 1554 PTO Cluch is soking black smoke. It is turning, just greesed all my mower spindles
Tony,
Your mower has a mule drive PTO. The belt starts at the clutch goes down to two idler pullys then back to the deck. You said you lubed the spindles, the only other moving parts (idlers) are preminently sealed. You cant lube these even if you wanted to, they do fail. The usually get loose, but sometimes the seize and smoke your belt. There is a tensioner arm on the deck, remove the tension, then (with the tractor off), spin by hand all of the idlers on the deck and the two up front on the tractor (mule drive). They should spin freely and quietly, if they are loose or wobble or make noise, replace them. Also while you are under there, spin the spindles (blades), they should spin freely as well, with no bearing noise or movement. The way to check that is to reach under, find the end of the blade and lift up on then pull down on, it should be tight. If it moves, the blade is either loose or the bearings are failing. These are the things that are the PTO components, All have to be working with freely moving parts, or you could have resitance that will smoke belts, or shred them depending on the failure.
As far as the clutch, it either works or it doesnt. With the tractor off and you sitting on the seat, turn the ignition to the run, not crank position. When you engage the clutch you should hear a "Clunk" when you pull the yellow knob. If so it works fine.
Hope this helps.
Nov 12, 2010 | Cub Cadet Garden
Motor won't start and mower very difficult to push
is there a puddle of oil under where it made the clunking sound, that would mean the engine is blown. another thing to check is to see if the motor bolts that hold down the motor came loose and is hanging down there by keeping the pullys from moving right..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Garden Logo
559 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
