Question about Acer P201WD CRT Monitor
The screen is blue and greem - Acer P201WD CRT Monitor
  • Acer Master
  • 1,606 Answers
The most probable cause is a break in the cable (red signal line). Try gently wiggling the cable at the computer connector and right at the monitor - these are the usual places for breaks. If this brings the red back into the picture (pun intended), you'll have to find a way to repair or replace the cable.
If you have red or white when the cable is disconnected (check cable warning message) or in the monitor adjustment menus, it is definitely either the cable or the computer video card.
If you can't get red to work at all with the tests in the preceding paragraphs, then it's time to open up the monitor. Check for continuity on the red line (pin 1 on the DB-15 connector to the red shielded wire where the cable terminates inside the monitor). Note: if you are not comfortable working near high voltage or don't know what not to touch, leave this task for an electronic technician. If the cable tests good, then it's time to troubleshoot the red cathode driver circuit on the CRT board, starting with the input signal. You'll probably need an oscilloscope for this job.
Posted on Jan 02, 2011
I am having sony dsc s 5000 cybershot camera. It is not used for some time. Batteries changed. But it is not switching on. Power greem light blinks and goes off.
sir,
what kind of battery you use ?, if you are using normal dry cell this happens, you have to use 2x Size-AA Alkaline or Ni-MH Batteries) which is recommended for this model, open the battery lid, check whether there is dirt or corrosion on the battery contacts, hope that this will solve your problem.
Jan 10, 2016 | Sony Cameras
Gateway 825gm wont tun on. just replaced on/off switch. greem light on power supply and mother board blinking green
Make sure the small cable from the switch to the mother board hasn't come loose. It comes loose fairly easily when reinstalling the cooling fan plenum. Its happened to me twice. Its even possible to plug it in the wrong place. Doesn't hurt to double check.
Dec 24, 2010 | Gateway 825GM PC Desktop
The tv looks 3d and doubles red and blue and greem
Sounds like a convergence failure. Here is my tutorial, let me know if you have other questions
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 22, 2010 | Samsung HCL4715W 47" Rear Projection...
TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Apr 08, 2009 | Sony Grand WEGA KF-50WE620 Television
Greem led timer light is flashing and the tv wont turn on what do i do ?
you need to replace the capacitors on the DM power board. You can get The V26 DLP DM repair kit at the following link which has the caps and full instructions with pictures.
http://servicemanuals.vstore.ca/
Apr 08, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Send solution
check if u intalled the speaker wires!!!
plz rate this post
Aug 25, 2008 | Intel D845GVSR Motherboard
Orange light
MEANS THAT ITS TIME TO REPLACED YOU LAMP/ THAT ONE YOU HAVE MAY GO OUT ANYTIME.
Jul 03, 2008 | LG RE-44SZ21RD 44" Analog Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
Screen goes black
Hai,
Do you see any dull image on the screen ?
If yes the inverter Card/Backlight of the screen is having problem.
Regards,
Aby
Dec 22, 2007 | Rosewill R900J 19" Flat Panel LCD Monitor
Acer P201WD CRT Monitor Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
