Question about Samsung RF4287HA
Can't figure how to remove glass shelf over dehydrator drawers. Seems to be attached to water filter assembly. Thanks for your help.
  • Samsung Master
  • 5,472 Answers
After you remove both vegetable drawers completely, look on the left side of the shelf (called the veg pan in the manual) for a round button. Press and hold the button while you tip the shelf up. Pull the shelf out slowly. This button is shown on page 20 of the manual.
The manual is available from Samsung on the product support page: http://www.samsung.com/us/support/owners/product/RF4287HARS/XAA . The direct link to the manual is currently http://downloadcenter.samsung.com/content/UM/201303/20130315164516140/DA68-01922A_1.5.pdf .
I hope this helps.
Posted on Sep 19, 2016
larryyb
  • 291 Answers
SOURCE: hotpoint side by side shelf removal
the bottom one should come up from the back first to get it out ,,, it may be stuck so be careful
Posted on Dec 12, 2008
SOURCE: Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Posted on Jun 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My FRT8B5EW4 has water building up in the crisper
This is a common problem when the drain for the condensate from defrost tries to get to the pan below your refrigerator. Almost every blockage may be a little different. The trick is to find where it begins and eliminate that problem first and then cleaning the condensate drain line out with a wet and dry vacuum cleaner. Click on the link below and if you have any questions or need one on one assistance let me know, Thanks, Sea Breeze appliancepartsse@yahoo.com
CLICK HERE=>HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 20, 2009
SOURCE: maytag refrigerators mtbe1956de
brute force on the glass shelf.... it was just stuck in place by the cold sticky liquid that had seeped under the edges and bonded the glass and plastic together
Posted on Jan 13, 2010
Testimonial: "Gee... you are really smart! When id doubt brute force is good."
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
I need a glass shelf for the crisper drawers 22 5/8
The glass shelf is no longer available but having someone cut glass to size will work, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
I need to change the water filter in my samsung srs618dp fridge freezer. I have the filter but cannot locate the internal part in the fridge i need to change.
For Samsung side-by-side refrigerators, there are two possible locations. One is in the upper right hand corner of the refrigerator. The other is behind the veggie drawer.
To access the filter, either remove the top glass shelf or the vegetable bin. Turn off the water to the refrigerator. If no filter is currently in use, remove the cap. If a filter is in use, remove the old filter. Turn clockwise to remove the old filter. Save the cap to reinstall if the fridge is ever used without the filter. Note the date when you put in the new filter and place the sticker on the filter. Remove the red cap from the new filter and align the unlock mark with the filter mark on the filter housing in the refrigerator. (Looks like an unlocked padlock with the u part turned 180 degrees from the rest of the lock). Turn the new filter counter-clockwise 90 degrees until the lock symbol (closed padlock) lines up with the mark on the housing. Use steady firm pressure - it will be hard to turn. This ensures a tight seal. Turn on the water line and check for leaks. If the filter isn't leaking replace the shelf or the vegetable drawer.
Samsung support for the SRS618dp is here: http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=2201&prd_mdl_cd=RS23DENS1%2FRAD&prd_mdl_name=SRS618DP&srchword=SRS618DP .
I hope this helps.
Jun 12, 2011 | Microwave Ovens
Maytag refrigerators mtbe1956de liquids have dripped on to the bottom glass shelf and seeped under the edges where it cannot be cleaned. do I have to remove the vegetable drawers and totally dismantle the...
Jan 12, 2010 | Refrigerators
I need to replace my maytag mmv5000 microwave door assembly
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 18, 2008 | Maytag MMV5000 Microwave Oven
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Samsung RF4287HA Logo
160 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
