Question about Samsung Star GT-S5233 Cell Phone
What is the security password? - Samsung Star GT-S5233 Cell Phone
  • 554 Answers
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Jan 02, 2011
How do I change my password and security questions?
Sign into your My Account page.
In the "Sign-in & security" section, select Signing in to Google > Password.
Type your current password and your new password.
Select Change password.
Change your Google Account password
http://ccm.net/forum/affich-926955-how-to-change-security-question-in-gmail
Dec 15, 2016 | Computers & Internet
Tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 | Computers & Internet
I cant change my password
Here's how to change your password:
  1. Log in to your PayPal account.
  2. Go to your Profile.
  3. Click the Security tab below your name.
  4. Click Edit next to "Password."
  5. Confirm your current password, enter your new password twice, and click Change Password.
Here's how to change your security questions:
  2. Click the Profile icon next to "Log out."
  4. Click Edit next to "Security questions."
  5. Select "Security questions" and click Edit.
  6. Complete the required information and click Save.
Jul 26, 2016 | PayPal Accounts
I forget my security questions answer
You may try the option "forgot password" and receive the solution for Password. Security question cannot be changed.
Apr 17, 2014 | Yahoo Mail
Forgot password code: 8015D002
Problem
You see the following error code and message when you try to sign in to Xbox Live:
Account does not exist.
Status Code: 8015D002
This may mean there's a problem with your account. For example, the security information for your account may need to be updated.
Solutions
Solution 1: Did you recently sign up for two-step verification?
If you recently turned on two-step verification, you may not know how to sign in to apps or devices that don't accept security codes. Some apps (like the mail apps on some smartphones) and devices (like the Xbox 360) can't prompt you to enter a security proof when you try to sign in. If you get an incorrect-password error with an app or device, you'll need to create a unique app password to sign in. After you sign in with your app password, you're all set to use that app or device. You'll use this new app password to sign in to your device instead of using your Microsoft account password.
You'll need to create and sign in with an app password once for each app or device that can't prompt you for a security proof.
  1. Sign in to your Microsoft account.
  2. Under Password and security info, tap or click Edit security info.
    If you're prompted for a security proof, enter it and tap or click Submit.
  3. Under App passwords, tap or click Create a new app password.
    A new app password is generated and appears on your screen.
  4. When you're prompted for your Microsoft account password on your Xbox console, enter the app password that you created online.After you sign in with your app password, you're all set to use that app or device. You will use this new app password to sign in to your device instead of your Microsoft account password.
Solution 2: Verify your Microsoft account security informationFollow these steps:
  1. Visit Microsoft account.
    Note If you forgot your password or can't sign in using your password, reset your password.
  2. Click Edit security info.
  3. Verify your security information. For example, verify the Phone number, Alternate email address, and Security question information.
  4. Sign out of your Microsoft account and then sign in again.
  5. Try to sign in to Xbox Live again.
Nov 02, 2013 | Video Game Consoles & Games
How can I secure my wirless wiht a password/security key?
Router passwords can easily be learnt of by other users in homes or offices. So make a case-sensitive password .Just check the few steps to secure your wireless router......how to secure your wireless router
Sep 03, 2012 | Linksys Wireless-G WRT54G Router
Acer P1265 projector asking for password
Security
This projector provides a useful security function for the
administrator to manage usage of the projector .
Press to change the "Security" setting. If the security function
is enabled, your must enter the "Administrator Password" first
before changing the security settings.
• Select "On" to enable the security function. The user has to
enter a password to operate the projector. Please refer to the
"User Password" section for details.
• If "Off" is selected, then the user can turn on the projector
without password.
Feb 06, 2012 | Acer P1265 DLP Projector
How to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    When i try to connect to a secured wireless connection my laptop asks for a device ownership password, that is either printed or labeled on the device. i cannot find where this password is?
    The password is not a preprinted password, it is a security password on your router. You need to log into the router and check your wireless security to see what you have used. If wireless security password is blank (use wap personal security), enter a password and then use the same for your computer when asked.
    Please leave feedback if this solves your problem, otherwise send more information about your problem.
    Feb 11, 2010 | Linksys WRT160N Wireless Router
    I need to add a password to my wireless network
    Do you want to secure the wireless network ?
    For that you will need to access the router set up.
    You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
    If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
    If your network is not secured yet then you will need to make it secured and enable password protection on it.
    Click Here to know more about how to make it secured
    Nov 12, 2009 | Computers & Internet
    Samsung Star GT-S5233 Cell Phone Logo
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
