Hi My Konica Minolta 1490 is asking me to insert the toner card after replacement of the toner of wish i dont have what can i do
  • 1,606 Answers
The toner cartridge may not be properly seated in the printer, or the electrical contacts may be dirty. Take the cartridge out and inspect all of the electrical contacts (any place where metal in the printer touches metal on the cartridge. Wipe off any dust or toner on these on both the printer and cartridge. Re-install the cartridge. Note: it should not take a tremendous amount of force to get the cartridge in or close the lid after it. If it doesn't fit together, something is in at the wrong angle.
Posted on Jan 02, 2011
Konica minolta c451 i replace magenta toner still asking replace toner
If it is OEM toner replace it under warranty and also check if the contacts on machine are not broken or bent. Also worth checking if the latch clip isn't broken too, as they do seem to go since the machine is not the latest.
Sep 22, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta 1590mf i replace toner still asking replace toner
did you refill? if so useless as there are electronic chips on them once done done!!!. Go out and buy OEM not third party toner
Jun 16, 2017 | Konica Minolta Office Equipment & Supplies
1.OPEN THE FRONT DOOR
2.PRESS CLEAR BUTTON
3.PRESS START BUTTON
4.DOWN ARROW AND UP ARROW
5.PRESS OK
6.CLOSE THE FRONT DOOR
Ready to copy
Oct 03, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta 1580-MFP how to reset replace low toner message printer ?
  • Purchase OEM toner, toner has chip on it chips say toner case is empty it is empty you replacing the toner will not fix that
May 04, 2016 | Konica Minolta Office Equipment & Supplies
C2801 konica minolta bizhub 501
TCR output abnormality. What is the status of your consumables (drum and developer)? You might need to replace the developer. Also, you should check if the toner bottle is turning; you should see it turning while the front cover door is open and the machine operates; if it is not turning, it is possible that the toner bottle was inserted wrong (by force).
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
My konica minolta 130 f is asking me to replace toner. I have opened it, refilled but is still asking me to replace toner
what you need to do is to change the toner cartridge. Refilling will not reset the toner IC inside the cartridge so by so doing, no notable change is witnessed.
Jun 12, 2011 | Konica Minolta Bizhub 362 Copier
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
I NEED THE PHONE # OF KONICA MINOLTA CUSTOMER
You can contact Konica Minolta customer care center at below details:
Konica Minolta Business Solutions U.S.A., Inc.
100 Williams Drive
Ramsey, NJ 07446
201-825-4000
If you wish to get the toner cartridge serviced or chnage it fro a new one, you can vist the below link whre you can find the information about their authorized service partner location wise.
Konica Minolta Customer Care
Regards.
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
249 people viewed this question
k24674
jasbo
jasbo
