Question about Sharp XL-DV60 System
Our Sharp Xl-DV60 has a parental rating lock active and we do not know the password.
1. after pressing stop button press the SET UP button.
2. press the cursor up or down button to select SYSTEM SETUP and press ENTER button.
3. press the cursor up or down to select RESTORE INFO and press ENTER button.
4. Enter 2486 and ENTER
this will restore to factory settings
Posted on Oct 29, 2011
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
Television question
That means The child lock has been activated.
I'll let you know if there is any solution for that.
Apr 09, 2008 | Haier HTF27R11 27" TV
What is the default password on the Sharp XL-DV50 dvd changer? I tried watching a movie and it says "Parental child lock in place" Thanks!
IT IS A LOCK PLACED ON DVD...YOU HAVE TO REMOVE THE PIN OF ITS MOTHERBOARD CIRCUIT OF DVD THAN TRY TO IT...IT MAY ERASE THE PASSWORD...AND LET DVD BE RESET AGAIN....
Jan 20, 2011 | Sharp XL-DV50 System
What is my parental lock code?
Go into system setup, choose 'restore info', and everything will be set back to factory spec.
The default parental lock code setting for that model is : 6629
Apr 06, 2010 | Sharp XL-DV50 System
Dont know password for auto install and need to re-tune
Brendan,
This is what I'm seeing here on your post, "
Dont know password for auto install and need to... sharp model 32ax5m Care to elaborate just a little..... Auto install what? Are you talking about parental lock?? Is the rest of the system locked out as well??? Have you tried the reset procedures in the owner's manual????
Bill
Nov 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
Sep 06, 2008 | Sharp 19R-M100 19" TV
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
Sharp 21 dig, color
Your parental lock is probably activated. That is most likely the V-chip doing its job locking out depending on the rating (PG,PG13,R etc) of the program.
Feb 25, 2007 | Sharp 21B-S10 21" TV
Sharp XL-DV60 System Logo
98 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
