Question about Frigidaire FRS23H7C Side by Side Refrigerator
Ice Maker I am not getting te water solenoid to open and let water in. The cube maker in the freezer cycles fine but no water for ice. I tookk the solenoids apart and cleaned everything is open. What activates the solenoid? I,m not sure what my model number is but it is the Gallery Series and is about 10 years old. Any assistance, E-Mail to james_11@comcast.net. Thanks, Jim
There is a switch inside t he icemaker that activates the water valve. Test for voltage at the valve when the ice maker is cycling. Or if it is easier , apply 110 volts to the two terminals on the valve. If it won't work replace it. It is uaually less than $20. (Most people never take it apart. ) If there is a drinking water dispenser, this will be a double valve and have two sets of terminals.
Posted on Jul 09, 2008
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
No water to ice maker
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues.
If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Aug 11, 2008 | Refrigerators
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Why has my American-style fridge freezer stopped making ice?
Hello Michael;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I will help you as best I can. The fact that your water dispenser works narrows it down.
Here are the causes for your icemaker not to fill:
1.) In the back of your refrigerator there is a solenoid valve for your ice maker and another for your water dispenser. The solenoid valve for your icemaker has the smaller plastic tubing that runs up the back of your refrigerator to the top. With the unit unplugged, remove the bottom back cover. remove the two connectors on the solenoid valve. Using a multi-meter, set the meter to the lowest Ohms. Place one meter lead on one of the solenoid metal contacts and the other lead metal contact. If the solenoid is good the meter will read; '0'.
Ice makers have control modules. The control module tells the water solenoid valve to open and for how long to fill the ice cube mold. Then a temperature sensor will tell the control module when the ice cubes are frozen. The control module will, if the ice maker is cast steel - will tell the heater to turn on for a period of time, and then tell the fingers to rotate to discharge the cubes, or if it is a flex mold, to flex. Then the cycle repeats.
The only one ice maker that is repairable is the one with the cast steel mold. The others are just throw-a-ways.
So, if your ice maker solenoid valve checks out, replace your ice maker. Do not buy it locally. You can save 40% or more if you buy over the internet
Nov 17, 2014 | Refrigerators
Replaced water valve but still will not supply water to the ice maker
Because your model has the mechanical type ice maker it is likely the ice makers thermostat is the most likely problem. Test ice maker by filling with tap water. Once the water freezes te thermostat tells the ice maker first to warm the bottom just long enough to cause the cubes to loosen in their slots and next th rake begins to cycle the cubes up and out of the ice maker and into the storage and auger pan. If the water just freezes and the ice maker does not cycle the you know the water control valve is new. The thermostat is what tells the cycle to begin. depending on the age of the ice maker just changing the defrost thermostat would be the best choice. I will display photos and links in a few moments, Sea Breeze
Mar 04, 2010 | Whirlpool GD2SHGX Refrigerator
Whirlpool ice dispenser not working, but water is
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Apr 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not work
Apr 01, 2009 | Frigidaire Optional Icemaker Kit
Amana af12538aes Refigerator No lights, ice, water
Jan 19, 2009 | Amana AFD2535DES French Door Refrigerator
Water to ice maker
Check pressure and flow to the solenoid, and after the solenoid. A filter may be slow. There is a small plastic screw on the side of the module that controls fill time. You may have to remove the square cover on the front of the module. A half turn at a time, then let it cycle.
Aug 09, 2008 | Whirlpool ET1FHTXM Top Freezer...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Frigidaire FRS23H7C Side by Side Refrigerator Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
