LOW MEMORY - Computers & Internet
  • 4 Answers
What's your detailed problem? Get a low disk space error when you trying to access any partition on your laptop partition?
If so, simply learn to extend your partition space with the free space of other partitions, like this: how to resize your computer partition space
But, if there is no enough free space left on the entire laptop internal drive, OK! Do not panic! You can use a larger drive to instead the old one.
No matter what you plan to do, simply save your drive well in advance.
Posted on Feb 03, 2015
  • 3 Answers
Have tried to delete all useless or unnecessary files, folders and programs to take chances?
This low memory problem still exists? Perhaps, you can try to resize all your computer partitions and see whether you can remove this low memory problem, just like this: https://www.youtube.com/watch?v=6jCeT7CbsKk
But, if the resizing way also makes no difference, you'd better change another larger drive or upgrade your RAM.
No matter which way you choose, just back up all your drive data well.
Posted on Nov 12, 2014
    Problem Solver:
  • 6 Answers
Hi Yeyek0905,
Good day!
I understand that your computer is running on Low memory.
If you have budget, it would be best to upgrade your RAM but then you may try the following solutions below:
For Low Virtual memory on Windows XP:
1. Click Start, then open the Control Panel.
2. Select Performance and Maintenance, and then click System.
3. Click the Advanced tab.
4. Under Performance, choose Settings.
5. Click the Advanced tab.
6. Under Virtual memory, click Change.
7. Under Drive [Volume Label], click the drive that contains the paging file (virtual memory) settings that you want to change. In almost every case, this will be your C: drive.
8. Click to select the "System managed size" option, then click Set.
9. Click OK three times and restart your computer
For Low Virtual memory on Windows Vista and windows 7:
1. Click Start, then open the Control Panel then select on Systems.
2. Click on advanced tab and select on settings for the performance option.
2. Select o the advanced tab then check on Virtual Memory(Change).
Uncheck the "Automatically manage paging file size", and select 'Custom Size'.
Increased the size based on the Recommended levels+200mb
You may also do the following to free up some space:
1. Delete Temporary files
a. Click on start and type in %temp% on the run option.
b. Delete all your temporary files.
2. Do a disk clean up.
a. Click on Start
b. Accessories
c. System tools
d. Select on disk clean up.
I hope this helps.
Best regards,
Jheycie
Posted on Jan 02, 2011
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Memory problems
  • Install more RAM
Mar 08, 2013 | Dell VOSTRO 3350
HP Laserjet M1522nf memory error how do i clear it up
Mem. low 1 copy. Press OK The product completed making one copy. The remaining copies have been canceled because of low memory. Press Cancel to clear the error. Break the job into smaller jobs that contain fewer pages. Memory is low Try again later The product does not have enough memory to start a new job. Wait until the current job is finished before starting a new job. Memory is low. Press OK The product memory has been almost completely filled. Allow the product to finish the job, or press Setup to cancel the job. Memory low Only 1 copy made The product does not have enough memory to complete the collated copy job. Break the job into smaller jobs that contain fewer pages.
GO TO THIS LINK FOR MORE INFORMATION
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=3442750&prodTypeId=18972&prodSeriesId=3442750&objectID=c01312064
PLEASE ARTE MY SERVICE
Nov 19, 2010 | HP LaserJet M1522nf Multifunction Printer...
My computer is telling me my memory is dangerously low. how much memory pgrade can be added to a satelite L25 s119
it means the size of your memory is low. you can increase this size by adding another memory into the memory slipts or replace with another memory which various from 32mb to abt 2mb per memory.
Sep 25, 2010 | Toshiba Computers & Internet
"low memory" message
Hello maxxoo,
There is a utility called Process Explorer on the Windows Sysinternals web site. It is very good at showing which processes are using a lot of memory. It may be helpful in determining what's causing the low memory problem. Process Explorer can be downloaded at this link:
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 10, 2010 | HP Pavilion a1610n PC Desktop
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
Low message memory
my massage memory is low how i increase my phone momery
Nov 27, 2008 | Sony Ericsson K750i Cellular Phone
Memory Stick Installation
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
May 19, 2008 | EliteGroup PM800M2 Motherboard
Shooting Speed Dropped
You can perform a Low Level Format of a memory card with this camera. Select Low Level Format under the following circumstances: - The continuous shooting speed has dropped. - The read/write speed of a memory card has dropped. If you perform a Low Level Format, the read/write speed of the memory card may recover, or the continuous shooting speed may improve. A Low Level Format may require 2 to 3 minutes with some memory cards.
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
