MODEL LCT2701TD SERIAL 501600648 Need new power board. Power light blinks repeatedly red instead of a constant red.
  • billymack50 Jan 03, 2011
    After removing back of tv I see one main board located in top right quadrant. Is this board the one to be replaced? Or are the filtering capacitors replaced individually?
  • 19,396 Answers
Hi.
Even if PSU is a very common failure on this model, the light blinking does not necessary means that the faulty part is the power board. The power board is simply a common fault.
The light is telling you that TV is in a forced stand-by state called protection. Protect mode starts when the main controlled board detects a wrong voltage or a short.
The main controller board switches off all voltages apart the +5VDC from PSU, used to keep standby mode.
The TV PSU supplies different voltages in different separate lines(+24V, +15V, +12V, +5V, +3.3v). The voltages are switched on and off powering low voltage control lines (this direct to FET switches that turn on the main voltage lines)
When TV is in protect mode, testing on PSU is done by jumping the control lines with the low DC line with same voltage. Each time the tech jumps a line, a determined voltage can be activated and tested. This job is done with all voltages, if PSU is OK, then the tech will follow line to inverter or to T-Con board. After testing PSU and boards, if no problem is found, more testing gets done (cold solder joints, diag points, etc.). Here a broad description of how to carry typical LCD TV testing: Before proceeding I assume you have technical training and a multimeter...
If you have already purchased the PSU, go on with replacement. PSU is a common fault, and if you are lucky enough, that will do the job. Let say that replacing the PSU without testing you have about 80% chance that PSU is the problem.
If you do not have the spare part, DO NOT REPLACE capacitors unless the PSU testing reveals a fault, or unless the capacitors are obviously bad (bulged, burnt and leaking, or bad at cap tester). Otherwise you risk to de-solder caps from a good PSU board.
Bad capacitors are often swollen and bulged.
Capacitors can store charge even when the power cord is not connected. They must be discharged by shorting their contacts or you risk getting electrical discharge that is dangerous for yourself and can damage your equipment.
The PSU board is located behind the TV back cover, and is the board connecting to power cord.
Here PSU and PSU repair service:
AKAI LCT2701TD POWER SUPPLY MLT168A
Akai LCT2701TD Power Supply REPAIR SERVICE MLT168A
MLT168A Power Supply
See also this Fixya thread, problem was not capacitors :AKAI MLT168A Power Supply - FixYa
Posted on Jan 03, 2011
  • 11,800 Answers
The blinking light signals that the power source is in protected mode because there's a short on one of its output rails. This might have been caused by a failure of some components of the power source (it tv's that old it's almost always the filtering capacitors) or another board has failed and it has acted as a short - in that case it's most likely the inverter board. So before replacing boards you must make sure you are replacing the correct one - open the tv, look at the boards and test the voltages.
If you are sure the power board is faulty then you will have a problem: you won't fine a new one anywhere, Akai sells them only to their authorized repair shops. You have 2 options:
1 - you search for a used one, retrieved from cannibalized sets, in online sites like Ebay and Craigslist, or at repair shops.
2 - you get your present board refurbished at a site like
http://www.tvboardsbank.com/
Posted on Jan 02, 2011
  • Azrael SRL Jan 03, 2011
    The power board is the one with the big transformer and a lot of big capacitors on it.
    Of course the capacitors can be replaced individually - it's the first thing you should try. It will be way cheaper than replacing the entire board. A good video tutorial on how to do that can be seen here
    http://www.youtube.com/watch?v=YCSNWi3UH...
RV FURNACE
It's hard to answer your question without the age and brand of your heater but the blinking of the red light can be a heartbeat, which indicates all systems are ok and there is power or the blinking is like 2 blinks, pause, and 2 blinks, pause repeating. That would indicate a failure code. In that case Google the model and serial number to get the failure code.
Oct 26, 2014 | Heating & Cooling
MY 4YEARS AKAI LCD TV IS BLINKING ORANGE LIGHT BUT
Read the info from the link below to troubleshoot the failure with your LCD. Try not for force the LCD to work because for the time being it might only need the capacitors listed in the link but if the lights is blinking red, then the failure is a bit more complex to repair.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
Feb 28, 2010 | Akai LCT2701TD Television
Blinking red diode, TV won't turn on.
The power supply is the culprit when the TV fails to power ON. In this case there are shorted diode(s) , defective capacitors or open blown resistors in the circuitry. These power supplies are not longer manufactured, the solution at this point would be to repair it.
Let me know if you require further assistance or you can write to jah2mil@hotmail.com
Jun 28, 2009 | Akai LCT2701TD Television
Will not power on, blinking red "power on" light
The power supply might have a shorted/defective diode(s), blown resistors, capacitors if the light is blinking on the front of the LCD.
I repair these power supplies, write to jah2mil@hotmail.com if you need further assistance.
Jun 24, 2009 | Akai LCT2701TD Television
BLINKING RED LIGHT AND NO PICTURE OR SOUND
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 27, 2009 | Akai LCT2701TD Television
No Picture or operation
The red blinking light indicates a shorted part inside the TV. It normally happens when the power supply is trying to compensate the demand for proper or clean power to the rest of the boards. Most of these power supplies have defective capacitors and shorted zener diode(s) as well open surface mount resistors.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Mar 02, 2009 | Akai LCT2701TD Television
Akai tv turned itself off and now only have a red blinking light-tv will not turn back on model no. lct2701td tv is 2 1/2 yrs old
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here.
Sep 16, 2008 | Televison & Video
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Jul 08, 2008 | Akai LCT2701TD Television
Tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Jan 23, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
