Question about Acer Computers & Internet
Where can I get drivers for my laptop e-machine e732?
  • Anonymous Jan 02, 2011
    I did try searching for emachines on Acer website. Didn't know they have a completely different website altogether.
  • 6,826 Answers
Go to the e-machine website and search for your model, in this case the e732.
Posted on Jan 02, 2011
Testimonial: "Thanks a lot. "
Error E 732 0001
E732-0001 Error Code: Reader Controller PCB is faulty
[ Case in the field ]
Description
E732-0001 can be displayed when a communication error occurs.
Cause
In the field, this symptom occurred because the Reader Controller PCB was faulty.
Field Remedy
1. Make sure that the connector between the host machine and the reader unit is securely fitted.
2. Make sure that the connectors on the Reader Controller PCB are securely fitted or there is no pinched cables.
3. Remove and insert the Main Controller PCB (Sub) from the Main Controller PCB (Main). If the symptom still recurs, go to the Step 4.
4. Replace the Reader Controller PCB with a new one.
E732-0001 Error Code: locks up during copying
E732-0001 can be displayed when a reader communication error occurs.
Cause
As a result of inspection, it was found that this symptom occurred because of poor soldering of J1302-34pin on the Main Controller PCB (Sub).
Field Remedy
1. Make sure that the connectors are securely fitted between J1302 on the Main Controller PCB (Sub) and J502 on the Reader Controller PCB and that
there is no pinched cable.
2. If no problem is found, replace the Main Controller PCB (Sub) with a new one.
E732-0001 Error Code: Because of poor contact of SDRAM
Description
E732-0001 indicates that a reader communication error has occurred.
Field Remedy
As a result of inspection, it was found that this symptom occurred because the SDRAM was not securely fitted on the Main Controller PCB. So, remove
and insert the SDRAM once again.
Sep 26, 2013 | Canon imageRUNNER C3200 Copier
Error loading operating system i min emachines E732
OS file damaged. please, recover or reinstalling OS
Aug 21, 2011 | Computers & Internet
Does anyone know how to get into an emachines E732 to upgrade the memory? I have removed 25 screws but cannot remove the back.
I have never worked on one but usually the memory slots are under a separate cover near the hard drive cover, underneath of the laptop.
Have a browse at www.insidemylaptop.com and see if they list you machine. If they do, pictorial information is there for free.
Hope this helps.
Feb 15, 2011 | Acer Computers & Internet
I have canon c2620n and when i turn it on give E 732-0001 i need help pleas
Description
Cause
Field Remedy
Cause
Field Remedy
Description
Field Remedy
Jan 31, 2011 | Canon imageRUNNER C3200 Copier
Ir 6000 E225 and E732 not go off
e225 - chk ccd unit connector image board
e732 chk scan readder controller,connector
Feb 09, 2010 | Canon imageRUNNER 5000 Copier
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Nov 17, 2009 | Canon Office Equipment & Supplies
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to "turn switch off and on". What could be wrong?
Nov 17, 2009 | Canon ImageRunner 2220N Copier
I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Computers & Internet Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
