Question about Microwave Ovens
My 2002 whirlpool microwave model # FGMV174KF started making popping noises, the same kind of noise if the is metal in it. We turned it on to pop some popcorn and it began smoking and smells like plastic burning. I think it is history. When I tried to look it up with this model #. It keeps coming up Frigidaire. Nothing under Whirlpool. I am beginning to worry that this is not even a Whirlpool. Can you explain?
  • 1314 Answers
SOURCE: Will not pop popcorn without burning it
use Orville Rickenbacker ah you know who lol set it for five minutes when you hear it slow take it out works for me no the oven don't need repair popcorn's tough the best way i know to make popcorn is an electric skillet yum yum
Posted on Feb 16, 2008
SOURCE: GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Posted on Mar 06, 2008
Illeagle
  • 525 Answers
SOURCE: My MW8108p is flashing and making noises
Do not use the oven! It sounds like the wave guide cover is burned and this poses a fire hazard should you continue to use it. Have a technician look at it and if this is the problem, it is usually a cheap fix.
Posted on May 23, 2008
Arius
  • 446 Answers
SOURCE: microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Posted on Nov 26, 2008
breddi2
  • 126 Answers
SOURCE: Microwave pops and sparks when running. Nothing
in the top of unit is a round cover and damage is coming from here. This is serious and needs to be checked out. the cover contains a stirrer that moves waves around<<circulates them>> in this cavity probably paint is thin and allowing waves to penetrate metal of cabinet. Call manufacturer and see if there is anything they will do for you before taking it upon yourself to either get repairman or get rid of unit.stirrer is probably damaged and cabinet burned from waves.
Posted on Apr 26, 2009
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
I have a whirlpool GH4155XPS-3 microwave. It has stopped cooking. Lights and turntable turn on but will not heat. It makes a poping noise every now and then, but not always and also makes louder noise than...
The magnetron has become defective, especially when it is followed by popping noises and is laboring are classic signs of failure. The other two components that should be checked are the high voltage capacitor and diode, but considering the repairs needed it would be cheaper to replace.
Feb 06, 2011 | Whirlpool Microwave Ovens
I have a ge spacemaker microwave JVM1640sj03. It makes a popping noise as the table turns when I have food in it. What can I do to fix this and why is it happening. Many thanks.
theres something metal inside the microwave look for a screw or something that may have been placed in there during a repair. metal causes the microwaves to reflect back to the magnetron creating the popping noise you hear.
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver microwave JVM1631WB002- making popping noise
The material is popping as a result of being heated.
Jan 19, 2018 | GE Microwave Ovens
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
Makes a popping noise and fan tries to start fan when oven is not on.
Can't explain the popping, but the fan has a heat sensor that will turn it on when it gets to a factory set temperature.
Jul 07, 2009 | Whirlpool GH6177XP Microwave Oven
Turntable makes a popping noise
The problem with turntable motor or coupler which sits on turntable motor shaft.
Nov 30, 2008 | Whirlpool MH7135XE Microwave Oven
GE xl1800 spacesaver microwave
It sounds like you could have one or two problems. Using the oven with metal in it could cause the magnatron to go bad at its tip causing it to arc and making a popping sound. It could be that there is bare metal exposed somewhere causing the popping sound. Take it in for service!!
Feb 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
