Question about ASUS P5RD2-VM Motherboard
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the above.
  • 23 Answers
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Posted on Jan 02, 2011
    Sergeant:
  • 223 Answers
Hi mgnair, brand is not important just frequency is important , i have check your board model it support following RAM
2 x Dimm, Max. 2 GB, DDR2 667/533/400/ Non-ECC, Memory , 667/533/400 - this are the frequency supported.
Good luck ! if you think your problem solved don't forget to rate
  • 335 Answers
You need to get some pc2-5300 ram. It runs at 667 mhz. Any brand will work. Just tell them you want 2 gig of pc2-5300 ram. If you are using windows xp, don't install more than 2 gig. Xp cannot use/recognize more than 2 gig of ram.
Hope this helps!
Regards,
Joe
Unable to install Radeon HD6450 2gb Graphic card on ASUS P5RD2-VM Motherboard. I am using 32 bit Window xp
Hi, you can download a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5RD2-VM&p=1&s=22
Please select your operating system.
Select manual and click on global.
Unzip the file before you can read it.
Upgrade the other drivers if some missing.
Run also windows update.
You may have to disable the onboard graphic in the bios.
You can also try to upgrade the bios by using the
asus upgrade utility.
The graphic card must be a PCI-E socket.
I guess the old driver is making a conflict as it is the same brand.
And download the latest driver for your graphic card here:
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.48&lang=us&rev=&ostype=Windows XP - Professional/Home
Sep 09, 2011 | ASUS P5RD2-VM Motherboard
My motherboard, P5RD2-VM, 400Watt PSU, 1GB RAM, Pentium D, when installed first time with a VGA card SAPPHIRE RADEON HD4670 512MB GDDR3 no problem. But after about one year, the VGA fan often turns itself...
Apparently yes. To determine that for sure boot in Safe Mode and run it there - the drivers will not be loaded so if it stops you will know it's a hardware problem.
Aug 25, 2011 | ASUS P5RD2-VM Motherboard
My mother board of asus p5rd2-vm is not detecting more than 2gbram memmory.any solution please.
The Motherboard supports a maximum of 2GB RAM. It is a hardware limitation.
2 x Dimm, Max. 2 GB
Apr 07, 2011 | ASUS P5RD2-VM Motherboard
What is the max memory i can install on my p5rd2-vm motherboard?
*********** board can support a maximum of 2 GB RAM.
Jul 09, 2010 | ASUS P5RD2-VM Motherboard
When i upgraded my system from win xp to win 7 ,my audio drivers are not working for the board ASUS P5RD2-VM Motherboard.kindly tell me link for upgrading my audio drivers
I am sorry i thoroughly checked ASUS website for those drivers they dont have audio drivers of it for windows 7, they only have for Windows XP upto 64 bit. Here is the link take a look.
http://support.asus.com/search/search.aspx?keyword=asus%20p5rd2-vm&SLanguage=en-us
Why dont you write to ASUS about this
Jun 09, 2010 | ASUS P5RD2-VM Motherboard
Upgraded my RAM to 2 x 1gb kingston KVR667D2N5 and windows XP will now not start. If I replace my old RAM, it works fine. Please help.
Your memory is not supported in Asus QVL = Qualified Vendor Listlist. There are only 4 Kingston DIMMs that pass Asus test for 667MHz. They are;
DDR2 667 512MB - E5108AE-6E-E
DDR2 667 1024MB - E5108AE-6E-E
DDR2 667 256MB - HYB18T256800AF3
Try exchanging the memory you bought for one of the above.
It wouldn't hurt to clean both sides of the memorys contacts. Two drops of alcohol onto a cotton sawb. Do not touch the contacts with your fingers.
Link to Asus P5RD2-VM site; http://www.asus.com/product.aspx?P_ID=eWs5ieITIWyIAA1U&content=specifications
Happy holidays!
Mike
Dec 20, 2009 | ASUS P5RD2-VM Motherboard
MY DRIVER ASUS P5RD2-VM <GREEN> HAD BEEN
Here is link download the driver make cd for further use
Nov 14, 2009 | ASUS P5RD2-VM Motherboard
Problem with Asus P5RD2-VM
i think you system also show the beep.
when this problem occured.
your ram may not be compatible for your system.
to solve the problem use this help
1-change the RAM
2-Ram insert into another Slots
3-may be 1 gb RAM not support to your system.
Apr 11, 2009 | ASUS P5RD2-VM Motherboard
Only recognises 2 gb when max supported is 4gb...
Is it all the same exact brand of memory, Dual Channel or no ?
You said its 800mhz ram and the mobo supports 600mhz, is it all 800 or 600 mhz or different speeds. Alot of motherboards will kick it down to match the other sticks some might not.
Jan 04, 2009 | ASUS P5RD2-VM Motherboard
ASUS P5RD2-VM Motherboard Logo
1,581 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
