Question about Goodman PHKJ048-1 Air Conditioner
Heatpump blows hot air when in heat mode but after some time starts blowing cold and then goes back to blowing hot again
  • 2,133 Answers
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element.
Check your heating sensor. May be defective. replace it.Thanks.
Posted on Jan 02, 2011
  • R Subramaniyam Iyer
    R Subramaniyam Iyer Jan 03, 2011
    Please also check your heating sensor for misplacing or loose contacts. Rectify it.
I have a KoolKing 3812-972 heating question
Last month I had the exact same issue with my HVAC system blowing out more cold air than hot. I didn't know what to do and so I had a heating service come and look at it. They were able to fix it and I was told that the issue had been due to my always keeping it on blast and that made the unit break down a little. You may want to consider how often you try and heat your home. http://www.advancedheatingandcooling.com/HeatPumps.aspx
Jan 07, 2016 | Heating & Cooling
Problem with heating up and staying heated.
Thermostat is sticking or heater core is blocked.do not keep running it or it is going to ruin the engine. It is running hot regardless if is blowing cool or hot air. Do not keep using the car.
Apr 16, 2017 | 1997 Oldsmobile Bravada
Heat blows cold air front and rear when sitting still or @ low mph.
Usually a sign of low coolant or a blockage in the circulation.
Feb 26, 2013 | 2003 Chrysler Town & Country
2007 Chevy Silverado dual climate control, even if passenger side is not on it blows cold air on passenger side and hot on driver side when in heat mode, also noticed cold air on driver side when A/C is on...
Just had this happen today to my 2007 silverado heat on the right side cold air on the left side. After engine was off 15 minutes and restarted heat was on both sides. I'm guessing a relay failed to open door to allow the heat to flow thus blowing cold air.will monitor diligently for a while.
Oct 20, 2010 | 2007 Chevrolet Silverado Classic SS New...
2005 s type jag a/c quit blowing cold air suddenly .just blows hot at any setting or on auto
hi,is this a heatpump or a ac unit only...if a heatpump ,there is a valve that switchs from heat tocool mode...go outside with unit running..put hand on big copper line,if it is hot your in heat mode..if cold your in cool mode....possible stuck change over valve if a heatpump...hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...if need more assitance..call..its free...good luck
Mar 26, 2010 | Heating & Cooling
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
I have a 1993 Acura Ledgend. For some reason my heater does not continue to blow hot air, it does for a few minutes and then begain to blow cold air. It does this often now. It works and then it blows cold...
first check to see that you coolant level is full, check it after the engine has cooled down,so there is no pressure in the system. otherwise you possibly have a head gasket in the early stage of failure
Nov 30, 2009 | 1993 Acura Legend
Mitsubishi heatpump not blowing out heat.
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Mar 09, 2009 | Heating & Cooling
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
