Question about Dryers
The "blades" inside the drum
  • 1,998 Answers
Yes they can you would end up removing the top panel or actually as they term it kicking it up and around the drum are screws that hold in the blades unscrew each of these and take out the change and the balls of lint as well then reattach if you have any if you need a diagram of your machine message me back and please remember to rank how this opinion has helped in your appliance situation we try to obtain 4 thumbs up on all our posts Thanks again Rick
p.s if you need a schematic of your dryer and how it comes apart send me the model number of your machine and tomorrow after 6 am eastern time i can send it to you sorry the site is down for maintenance this evening
Posted on Jan 02, 2011
Testimonial: "Your terrific! I didn't think to look behind the drum for screws and there they were. Thanks for the very simple answer to a baffling (for me) problem"
Toner leaking and low quality copy
I would check the transferbelt/wastebox/cleaning unit to see if it is full or have a problem with cleaning.
If it is full it will make a soundt as some toner is forced out of the wastebox. I've seen a few examples of cleaning blades that does not clean smoothly too. When the blade moves toner scatters.
It it is full, empty the wastebox and change the cleanin blade.
If not, check the drum and the drum cleaning. I've had a "jumping" cleaning blade on the drum too, also resulting in toner scattering inside the machine. It that is the case, the blade must be changed.
In order to make this machine run kind of OK, you need to keep it super clean, change developer and other parts at least as often as Ricoh says in the service manual.
Make sure you have the latest firmware model, and the right toner.
It is a machine that runs dirty, and based on the POS Adonis series of machines from Ricoh.
For other viewers here, stay away from the Ricoh Aficio 350/450, 1035/45, 2035/45 and newer models like the MP 3500/4500.
You will notice companies that sell copiers from differente brands often have decided not to sell this model from Ricoh, and just choose a different make/brand as their machines (in this segment) are better.
Jul 07, 2017 | Ricoh Aficio MP 3500 Digital Copier 35cpm...
Fan noise coming from inside a kenmore elite refrigerator..
Sounds like the fan gas come loose on the shaft and slid into its cage.
Dec 15, 2013 | GALAXY Microsystems 25.4 cu. ft....
Craftsman 6.5,22 inch cut. model# 917.379470
does not sound good the off balance of a loose blade could have caused the rod to break inside the engine the age of mower and how much use it has had could be a factor only way to really know it to look inside the crankcase.
Jun 06, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Thumping sound when drying?
change your belt or replace the spring that tensions the belt
Jul 13, 2017 | General Electric GE DBVH520EJWW Electric...
I was mowing the lawn, and I ran over a dirt *****. Now the engine will not start. It also sounds like something is loose inside. I hear a few clunking sounds when I pull the cord. Do I need to take...
Yoy can try tightening the blade bolt. i know it sounds funny but if the blade bolt is loose (or even alittle loose) the blade balance throws off the engine balance and can cause it to
1 not start
2 make loud clunking noises when trying to start
3 make a real racket if it does start
try flipping the lawn mower over and just tighten the bolt that holds the blade in place.
That should fix your problem.
Please dont forget to rate my answers
Thank you
Jun 17, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
Printer says "drum end soon". I don't even know
The drum is the part of the printer that the image of what you want to print is stored on by a laser drawing on that drum. That drum is then charged with an electrostatic shock that will draw up toner particles from your toner tray that will eventually be transferred to a piece of paper that will be heated to fuse the ink particles on the paper. That drum is photo sensitive and eventually looses its ability to be charged. You will then have to replace that drum.
Feb 09, 2011 | Brother MFC 7840W Printer
Makes a noise like there is loose change in the dryer. Grey marks are coming off onto the clothes. checked. there is nothing inside the dryer or in the pockets of the clothes. Still happens- even with...
This sounds like a faulty drum bearing. The grey marks you are seeing are grease from the bearing. The loose change sound is from the remnants of the bearing rotating as the drum turns.
Mar 09, 2010 | Dryers
Sounds like something is loose inside the dry drum
Unplug dryer!!
There should be 2 5/16th screws on the bottom panel in front. Then there are 2 more on bottom of top panel. Take off wires to door switch. Take off 4 screws to front bulkhead. Pull it off. Note how belt goes on. Take it off and pull drum.
I would first rotate drum by hand and see where noise is coming from. If inside one of the baffles in drum, you can easily lossen up screws to remove baffle to get things out.
Jan 10, 2010 | Speed Queen AES28AWF Electric Dryer
Kenmore HE2 Dryer Blades Loose
Yes. Depends on your model. The top, front and rear come off of some. Very easy fix. Your screws should be on the floor under the dryer.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
