Question about Canon Office Equipment & Supplies
I cannot find any info to correct my Canon Pixma MP 110 printer which displays " Waste ink absorber is almost full see manual" a manual was not supplied with the printer, only a quick start guide was supplied. can you please help me???
  • auswels Jan 08, 2011
    Hi Michael34
    when I select the service mode these are my listings;
    1. Fireware:01.58
    2.Lang.select
    3.Card protect
    4.Market model
    5.Counter access
    6.Nuram Access
    7.Factory default
    8.Mechanical set ..... there is nothing in this list that corresponds with your listing that tells me to select
To fix this error: Turn on your MP110. After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.Enter SERVICE MODE by pressing: Menu-Copy-Scan-Copy-Copy. Next, select TEST MODE. Now select [8] PRINTER TEST in TEST MODE. After that select 3. [EEPROM CLEAR] And then 5) Select 0. [INK COUNT]. Now press the [OK] key. After yuo do that, press the [Stop/Reset] key (returning to the state of 3) and then press the [ON/OFF] key.
Posted on Jan 05, 2011
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Mar 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
"The Waste Ink Absorber is
Hi there. Open this link http://www.mediafire.com/?yan3ytvdumt and download the software.The install the software and click on the reset button.Open this link for more detailed info http://tricks-collections.com/reset-canon-pixma-mp150-mp160-mp170-mp180-mp450-mp460-mptool-software/
Dec 23, 2010 | Canon PIXMA MP170 All-In-One InkJet...
HOW DO I REPLACE MY CANON PIXMA MP 110 WASTE INK THANKS VERY MUCH
Replacing is not the only problem, Canon didn't make any parts available for that machine and there's no way to reset the error code.
Dec 04, 2009 | Office Equipment & Supplies
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Jul 01, 2009 | Office Equipment & Supplies
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
May 16, 2009 | Canon Pixma MP450 All-In-One InkJet...
Cartridge jammed / Waste Ink absorber almost full
Waste ink pad or pads are full and need changing.
Under your ink carraige cradle it is,
It will be full, bit of a dirty job.
Hope this helps
Ric.
Apr 17, 2009 | Office Equipment & Supplies
Error Code 5 on Canon MP160 Printer
your problem is waste ink absorber is full,you need the canon mp tool which is use to reset the counter of your printer,but you must dismantle your printer to clean the waste absorber because if you will reset the counter without cleaning it, all waste ink will overflow on your printer.
Apr 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printers Problem Canon MP 145 code E27
Try this fix.....CLICK HERE
It works the same for the Canon MP 150 or MP 160
Jan 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
Oct 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
119 people viewed this question
old marine
old marine
