Question about Acer Aspire 5610-4648 Notebook
My Acer Aspire One has been ok until recently when i turned it on and the screen runs windows Xp several times. It turns off and on several times without ceasing, and the only thing I see is the Windows XP and then second thing i see is press f2 OR F12. I therefore pressed Alt f10 to try to reset it to factory settings but to no avail as the problem persists. I cannot even boot it with any system disk because it does not settle to the window icons, it just runs continuously.. I dont know whether it is something to do with hardware or the screen or the operating system. Please help! Your help will be appreciated.
    Sergeant:
    Champion:
  • 215 Answers
Hi,Your operating system is corrupt,probably as a result of an infection or as a result of the Hard Disk failure.so i'll advise you take out the hard drive,back-up your files if any and format your system,then re-install operating system.
Posted on Jan 02, 2011
I am using acer aspire 4315.but i can't install windows xp.how can i install windows xp 3
tHIS is the guide:
Turm on the laptop, open the cd drive and slot the cd of the windows xp 3 and then close it.
Turn off the pc by pressing and holding on the power button until the system turns off,
Then turn on the pc and allow it to start.
On start up booting, a screen will appear asking you to press any key to boot from cd, then press the enter key and allow set up to run.
follow the screen instruction and guide until installation finishes.
More guide, then mail me for more help, brightprofiles@yahoo.com
****UTILITY SOFTWARE GUIDE FOR FIXING PC ERRORS, SPEEDING UP PC, DRIVER UPDATE, INTERNET SECURITY... OPEN FOR ACCESS/SELECT TOOLS*****
Dec 15, 2010 | Acer Aspire 4315 Notebook
Cannot shut down
I want you to try this first reset the CMOS bat , put a new Hard disk install EXP .
good luck
Dec 19, 2009 | Acer Aspire 4930-6862 Laptop
Configure wireless connection on acer aspire one
Some people like to disable the zero config service for security purposes. Here's how to re-enable it (assuming you're using Windows XP) -
  • Go to Start then select Run (or use (WinKey+R key combo)
  • Put in services.msc
  • Keep hitting the W key until Wireless Zero Configuration is highlight.
  • Double click to bring up the properties of this service
  • You want to make the Startup type set to Automatic and then also click the Start button (next to the stop button and below the "Service status" line.
When you're done just push ok to get rid of the properties window and you can close the services screen. You should now be able to connect to the wireless.
Oct 06, 2009 | Acer Aspire One PC Notebook
Acer Aspire 3680 In a Loop
What I wanted you to clarify was the message that you noted as "something to the effect of 'Beginning of physical damage'", but you only saw it the one time I see on rereading the post, so never mind.
Have you tried doing a factory restore using the recovery media? Try pressing Alt + F10 on booting to get to eRecovery Management.
Dec 29, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Aspire 5100
Sounds like both of you have what is called 'Microsoft Blue Screen Of Death' and is irreversible, but is fixable at the same time. If you need files on your computer then follow these instructions
  1. Turn on computer and Insert Windows XP Installation Disc that came with your computer
  2. Wait until it says 'Press any key to boot from CD....' and press any key
  3. Wait until it comes up with prompts and choose 'Install Windows XP
  4. Choose to install XP without formatting the hard drive and choose a made partition (C Drive) to install NTFS
  5. Install and now your system will be working again. You will be prompted from now on though which Operating System you would like to use. Always select the first one
  6. Enjoy
For if you want to erase the hard drive
  1. Follow steps 1 - 3 in above instructions
  2. Choose 'Format Hard Drive'
  3. Select create partition in Hard Drive and set it to the maximum space and call (C)
  4. Select NTFS and go through instructions
  5. You won't be asked to choose a OS as there is only one to choose from
  6. Enjoy
Hope This Helps
Aug 06, 2008 | Acer Aspire 5100-5022 Notebook
LCD problem
ok just go to Start- Settings -Control Panel - Power options -click on it inside that turn off monitor option Never u say and system stand by u make it as Never apply and say ok it will not go to stand by mode
Jul 30, 2008 | Computers & Internet
My Acer Aspire 5100 is messed up ?
I had a laptop in my shop recently with the same problem. If you moved the machine at all it would blue screen. The problem was a connector on the motherboard that had came loose and was shorting the system out. I had to tear the machine completely down, and it took me hours to find it. With that said, you have a short somewhere on the board, whether it be a loose connection or bare wire, and it would be in your best interest to take it to a professional to find the problem.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5050 Won't Boot.
Your problem could be windows vista isnot installed properly
i assume in the beginning, your laptop come with windows xp.
if you want to go back to windows xp, you can still use alt+f10, as long as you don't delete the recover partition.
Just boot and press Alt+F10, it'll give you recover screen.
Mar 20, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
