Question about Electrolux Washing Machines
Electrolux ewf 1090, have an electrolux ewf1090 front loader washing machine. When the machine finished its wash cycle the lights are showing "cold" and "0 spin" and the washing feels wet and rather hot and doesnt quite seem washed. I dont know at what stage its malfunctioning. spin works, and the machine is pumping out ok. any help?
Ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
Washing machine stops on rince cycle
when the unit sense a strong vibration it automatically stop the unit. unplug the unit and wait for thirty seconds then open the lid and redistribute the cloths inside to balance the load then close lid then plug unit then push power and program your washing again
Feb 24, 2016 | Electrolux Ewf1090 Front Loader Belt Part...
How do I replace the door handle on a electrolux front loader ewf 1074 washing machine
hi
you need to take the door apart to be able to replace the handle
is a easy job but remember the order you take it apart to be able to put it back on
Apr 23, 2015 | Electrolux Washing Machines
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
May 27, 2010 | Electrolux EIFLW55HIW Front Load Washer...
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Apr 23, 2009 | Electrolux Washing Machines
Washing Machines Logo
1,078 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
