Question about Sharp AR-C270 Color Copier
Sharp ARC270, washed out color
All the color are washed out, and there is no error code number. The tech
said the developer need changing. Is it that simple? The developer was changed very recently and not that many copies was made before the problem occurred. Changing the developer is very expensive.
  • Sharp Expert
  • 1,326 Answers
I would have to say that they did it wrong or that you have a transfer or drum charge problem
Posted on Jul 10, 2008
Error code 59.61 on hp color laserjet 5550
Book says that it is the cyan drum drive assembly that needs replacing. Part number RG5-7723-000CN.
DO NOT attempt to do it yourself. A tech needs to do it.
Feb 19, 2015 | HP LaserJet Office Equipment & Supplies
How can I convert Ricoh development counter to pages
Best thing to do is contact Ricoh Services and Support (1-800-432-9787) for service. A Ricoh Tech/Engineer would need to go into Special Service to change the Accounting type preferences, as end-users shouldn't have access to this Special Service function. Additionally, once this change has been made, you cannot revert back; you can only change this setting once.
Jun 02, 2014 | Ricoh Aficio™ SP-C210SF Printer
P-9, P-21, P-28 error code
P-9 Replace the black developer and drum unit.
P-28 Have tech clean the IDC sensor located under the transfer belt forward section (right side of the copier) the rear one towards back of the machine right side There are two clean both
Above two codes should then fix P-21 which is the fault that registration is not right. And Since the Black Image unit is the reference for the other three color in regards to Registration that is why P-9 and P-28 need fix first.
Apr 17, 2014 | Konica Minolta Bizhub C364 Color Copier /...
Received an error code dl f on my Kenmore Elite 45986. Replaced the locking mechanism and I am still receving the same error and results. It just clicks and gives this error code. Thanks "dl F" error code...
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
May 11, 2009 | Kenmore Washing Machines
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Canon 1150 E020 04E0 Code error
change all 4 developers plus blow clean both developer sensors you can find these sensors next to the black developer assy it has one screw
Jul 23, 2008 | Canon CLC 1150 Color Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Jan 29, 2008 | Canon CLC 1150 Color Copier
Sharp AR-C270 Color Copier Logo
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
