Question about Carrier Heating & Cooling
Carrier furnace 58STA blinking 3 fast then 3 slow, whats this code mean?
5 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Carrier Furnace is not blowing Heat
heres the manual for the unit, look at pages 46-47 and theres a trouble shooting ladder schematic that asks what the systums are then gives the solutions for the fix. if you are still having problems you can request to talk to me and I'll be more than happy to help.
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/58st-13si.pdf
Posted on Jan 11, 2009
tborn6
  • 700 Answers
SOURCE: Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Posted on Jan 21, 2009
  • 185 Answers
SOURCE: my carrier 58sta furncace is blowing cold air constantly
Code 33 is "limit is open or flame switch is open"
FIRST make sure the filter is clean. Turn off unit then turn back on.
if it works but then later gives you a 33 code then you might have a dirty a/c coil (if you have a/c) that will cause the limit to open. 1st try that
Posted on Mar 21, 2010
  • 14 Answers
SOURCE: Carrier Performance Boost 80 has
this indicates fault 33, on inside of access panel will tell you faulty switch. i believe off top of my head is pressure switch open, this a safety switch to verify that inducer fan is working, several things besides a failed part can cuase this, there is a rubber hose going from the inducer fan houseing to the safety pressure switch, remove hose from fan housing and run a small stick ,wire or torch tip cleaner, down the acces port, calcium builds up inside the port and blocks the sampling of pressure, reassemble and try it, if this works add it to yearly maintenance could need new switch or inducer fan motor, these need to be replaced by a tech, also birds can block flue pipe
Posted on Feb 02, 2011
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
HK42FZ034 status code light blinks in pattern
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
Apr 13, 2014 | Carrier Furnace Control Board Bryant...
On my Carrier Furnace the trouble shooting light has 3 fast blinks and 3 small blinks what does that mean?
Hi, this is a code telling you that something on the furnace has failed. You will have a chart with a list of codes and the amount of blinks fast and slow that will tell you what the problem is and what you can do to solve this. The chart may be glued to the panel, or on the control module it self. The code might be a 33. It might be a roll out switch has tripped and needs to be reset, or what ever, you will need to look for what it is saying. To reset when you find the problem, unplug power or shut off breaker, and turn back on in a minute or 2.Let me know the out come.
Shastalaker7
A/C, & Heating Contractor
Mar 30, 2011 | Heating & Cooling
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like thathttp://www.scribd.com/doc/20861415/Carrier-58pav-Service-Maint i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
My carrier 58sta furncace is blowing cold air constantly
Mar 21, 2010 | Carrier Heating & Cooling
I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Feb 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Jan 21, 2009 | Heating & Cooling
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
452 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
