Question about Roper REX4634KQ Electric Dryer
How do you connect the belt to the pully, and drum?
    President:
  • 2,468 Answers
Loop the new belt around the drum,then take loop of belt under the idler pulley wheel and pull back on wheel to get slack to put remaining loop onto motor pulley shaft,then slowly release and idler will tighten up the belt automatically
Posted on Jan 02, 2011
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Drum is hard to turn. When running, there is a loud high pitched squeal. I oiled the pully area in the back, and the noise stopped and the drum turned, briefly. Now, the drum doesn't turn at all. ???
if you got oil on the belt or the part of the pully where the belt rides then the belt is sliping and wont turn the drum.
you will need to get the oil off of the belt or buy a new one and you will need to get the oil off the motor pully and the idler pully and if any oil is on the drum.
This is where I would start given the information you have given.
Oct 06, 2010 | Kenmore 83042 Electric Dryer
How do you rehook the belt up for the drum
tricky but belt around drum then pully tensioner at bottom of dryer the belt feeds through pully then onto motor gotta move pully while putting belt on motor take s some practice kinda hard to expain
Aug 19, 2010 | Kenmore 63942 Dryer
How do i go about replaceing my washing machine belt
If your machine is a front loader, then you will need to remove the rear panel, normally this is just a screwdriver requirement. make sure you take your old belt as the supplier will require the numbers from it to ensure you get the correct size. There are many different belts. Place the belt onto motor shaft and then onto drum pully wheel as far as it will go. You then need to rotate the drum by hand to feed the belt onto the wheel. After you have done this you may need to line the belt up by moving it across the grooves on the motor spindle. to do so again move the drum pully around and at same time move belt across the motor pully groves until belt runs central on drum pully. This may seem awkward but you will be suprised how easy it really is.Also it will save you a fortune by doing this yourself
Mar 13, 2010 | Washing Machines
Belt came off hotpoint washer
hello mam
before trying please check the belt tension. and if you inspect the threads are visible on the belt which will be seated on the pully please change the belt and to put it back
1.plase the belt into the motor pully first. and then using a screwdriver hold the belt into the drum pully slowly rotate the drum as you rotate the drum you should hold the belt along the pully.
Oct 04, 2009 | Washing Machines
Hotpoint wf240 replacment of belt, i cant get it on.
Hi, put the belt on the bottom pully and feed the rest up to the top pully, fit the belt on to half of the top pully, now open the door of the washer and very carefuly turn the drum while holding the belt tight to the pully, take care not to get your fingers trapped, make sure that the belt stays on both pullys by rotating the drum by hand a few times, if it all looks ok and central then the jobs a good un.
Mar 03, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Belt replacement
belt is a streach fit
put belt onto motor pully first then feed belt round drum pully
Aug 16, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Roper REX4634KQ Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
