Question about Gigabyte GA-8S661FXM-RZ Motherboard
Dear Technical Team, I have CPu with motherboard of GIGABYTE 8S 661 FXMP-RZ. The hard disk is working on IDE . But when I conneted another HDD connected with its SATA slot, it is not working. Would you please tell me which driver to be used for this one? I want to work both IDE and SATA since one HDD is of IDE and other one is of SATA type
  • 23 Answers
You have to check your BIOS and ensure that the SATA is enabled.
Under Integrated Peripherals look for:
SiS Serial ATA Controller
Enable SiS Serial ATA Controller.(
Default value)
You may also want to check your boot Priority (if you are booting from the IDE Drive)
Advance BIOS Features
Hard Disk Boot Priority
If you need to configure the SiS 964 RAID then let me know.
Good Luck
Posted on Jan 02, 2011
  • 335 Answers
Can you see the sata drive in the bios? Also, are you tring to boot from the sata drive, or is it an additional drive for data storage. If the sata drive is brand new, then you probably need to partition it and format it.
Boot into windows (from the ide drive) with the sata drive connected (data and power cables). Once in windows, right-click computer (my computer in xp) from the start menu, and left-click 'manage'.
Now, click on 'disk management'. If the drive is new, you will see it in this window, and you can partition it and format it.
Please let me know if this works or not. If not, I can help some more.
Regards,
Joe
I have a 81845gvm-rz gigabyte motherboard with internal HDD of 40GB capacity, now i am looking upgrade my internal HDD some where near 500gb is it possbile doing it. i need more free space on my c:\ drive...
The new harddrive technology you refer to is SATA.
A SATA power cable is used,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
,and a SATA Data cable is used,
http://en.wikipedia.org/wiki/SATA
To the upper right of the page shows a SATA Data cable connector, on the end of a SATA Data cable.
Below it is an example of a SATA header on the motherboard. Color does Not matter.
The SATA power cable connector has 15 pins. The SATA Data cable connector has 7 pins. Both connectors use an L shape on the inside, to line up the connection.
The type of older Harddrive technology you are using now is IDE.
It is also known as PATA.
Uses a 40-pin flat ribbon cable for the Data cable. (Note* Only 39 pins are used. One hole is blocked off, or has no wire )
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
The Gigabyte GA-81845GVM-RZ motherboard's Storage Controller Type support is IDE, [ DMA/ATA-100 (Ultra) X 2 ],
http://www.dealtime.com/Gigabyte-Gigabyte-Technology-i845GVup-to-2GB-DDRDIMM-3DDR/info?tab=specs
There are no SATA headers on the motherboard,
http://www.ebay.com/itm/Gigabyte-GA-8I845GVM-RZ-Motherboard-DHL-UPS-3-8-DAY-/390337518730?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D180645618978%26ps%3D63%26clkid%3D5166955561701266148
HOWEVER,....all is not lost. You can install a SATA Adapter Card in an unused PCI (White long slot), and use a SATA harddrive.
Example of a SATA Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329305&CatId=1455
With the above SATA Adapter Card model, you will have 4 internal SATA headers. They are on the adapter card.
[ Also advise maxing out the Ram Memory, and using the best Intel Pentium 4, Socket 478 processor, that you can obtain.
The CPU Support Chart is available on the Gigabyte Support main page]
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 26, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
NOT WORK SATA HDD
when the system restart press del and go to bios in bios you have to click optimised defults then save and exit still the hard disk isnot detected then change the hard disk
Dec 30, 2010 | VIA Gigabyte GA-7VT600P-RZ KT600 Socket A...
My motherboard cant detect hard disk ,disk driver and when i start my computer it dint show HDD LED light (red light) and it show "No Hard Disk detected, Please insert Hard Disk and Press Enter. i...
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Dec 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Will this motherboard support 250 gb harddrive ide seagate
is it SATA? it shouldn't have a problem with hard drives unless the plugs are different. if the HDD is sata and you got a sata connection on your motherboard then you're all set
Feb 21, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided; http://www.easeus.com/resource/install-ide-hard-drive.htm
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte; http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1766
To view the manual you will need to download and install Adobe reader;
http://www.adobe.com/products/reader/
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Cheers'
Mike
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Gigabyte ga-8i915p duo motherboard ide problems
RAID stands for Redundant Array of Inexpensive Disks.
The RAID system uses multiple number of hard disks to give a fast and fault tolerant storage using several disk controllers.
There are various levels of RAID, for info on RAIDs check out
http://en.wikipedia.org/wiki/Standard_RAID_levels
Apr 03, 2009 | Asrock P4VM8 Motherboard
Mother board problem
need more info. ? have you tred other drivs. ?
Jan 07, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hdd installation
The capacity that a motherboard can support is designated by the BIOS.... a few years ago when HDDs started to get big, there was an issue in supporting disks above 137GB as this exhausted the old HDD addressing system..(BIOS), to rectify this the BIOS code was re-written to support 48bit LBA (Logical block addresses) so as long as you have up to date BIOS for this motherboard, it should be alright.
you should be able to install any capacity available on IDE as long as you have updated the BIOS to the latest version (check the Giga byte website to download this)
If you wish to upgrade your PC further you can get a SATA/PATA adapter, or you can get a PCI SATA, IDE or SCSI controller card. Effectively there are very few limitations to the number of disks nowadays.
Dec 05, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hard disk installation
Bummer I couldn't even find that MB on Gigabyte's site, however a more to the point question for you would be: Are you going to use a XP operating system? If yes than down load the drive's Mfg disk software. Usally you can than creat a boot disk to setup your drive. Pay attention to the jumper settings listed on the drive. If its a PATA drive = serial ATA-133/66/33 you will need to set the jumper for a master or slave or master with a slave. If its a SATA and your board supports SATA II you will need to remove the jumper to allow up 3.0gig transfer rates. If your board does not support SATA II than leave the jumper on. If your board does not support SATA I = 1.5gig tranfer rate, than you can not use this in your system.
Dec 04, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Gigabyte GA-8S661FXM-RZ Motherboard Logo
121 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
