Question about PC Chips M957G Motherboard
I just got a usd m957g in an Xblade tower ...and it wont boot i have no beep on power up all the lights are on and i hear the hdd spin up! any one know what i shod do?
  • PC Chips Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Jan 02, 2011
Atx case manual mid tower
To fix this you need to check what causes this problem. In this case it is high temperature. This can be caused by faulty(broken) sensor or a high temperature.
If its indicating which of the 3 sensors is causing this alarm, investigate that sensor. Check if the coolers are dusty and clean them if needed.
Also it could be the the temperature of the alarm is set to low, adjust it if possible/needed.
Another (not really a)solution is just to disconnect the the sensor that is causing the alarm and just leave it hanging inside the case. But I only advise this if you want to get rid of the alarm.
Jun 11, 2013 | A-Top XBlade Mid-Tower Case
Pet pulled out power supply cord and now tower won't work
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 04, 2012 | HP Computers & Internet
Why is the xblade heating up when booting
The overheating problem could be a faulty fan or the heat sink is clogged with dust.
Your compter fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
May 15, 2011 | A-Top XBlade AT859A-BK ATX Mid-Tower Case
I need a wireing diagram xblade digital display
i just install a new mother board in the x blade when booting a message comes up saying thy computer is shuting down its heated over 95 help me solve this please
Mar 06, 2011 | A-Top XBlade AT859A-BK ATX Mid-Tower Case
Alienware Aurora Desktop does not boot, has no HD activity
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
Jul 06, 2010 | Alienware PC Systems Alienware Aurora High...
Have same prolbem as kazza. have tried another tv but still cant get anything on screen cant get menu screen on tv
Does discs still load/eject into the drive? If so, you may have a corrupt HDD.
Try to boot into the recovery menu:
Power on the console (green light)
Power off using front power button (red light)
Now power on from front power button, continue holding the power button until you hear a 'beep'. Still holding the power button, a few seconds later you will hear 2 quick beeps, as soon as you hear the 2 beeps, let go of the power button and it should boot straight into the recovery menu.
From the recovery menu, choose to restore the HDD.
Dec 27, 2009 | Nintendo Wii Console
Hi, when i boot the system nothing appear on the system. i initially checked my ram it was not workinhg so i bought a new one but still the system won't start up!! it is a p4, intel d865, 512 ddr ram ,...
If you doesn't hear any beeps, at least you must hear one beep.
Clear CMOS or remove the Lithium Battery CR2032 in the motherboard about 1 minute, to know which MB is hang up with processor, then put it back again & power it on.
Aug 17, 2009 | Personal COMPUTER - LENOVO THINKCENTRE A61...
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
SATA HDD not connected ?
I had to jumper the drive to slow it down. Then it does not show on the first cmos screen with the dvd drive, but the system does show it in the boot order and does find it.
Mar 12, 2009 | Pc Ware PC CHIPS: PC-Chip M957G...
PC Chips M957G Motherboard Logo
53 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
