Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
I HAVE 8GB TRANSCEND PEN DRIVE, BUT IT IS NOT DETECTED BY MY PC.
  • 335 Answers
Try the usb drive on another pc to see if it is dead. If the usb drive works on another pc, reply to me and I can help more. If the usb drive does not respond on another pc, it may be dead.
Please reply with test results, and I can help more.
Regards,
Joe
Posted on Jan 02, 2011
  • John 222 Feb 03, 2011
  • shahparth Feb 06, 2011
    usb runs on another pc.
  • 6,826 Answers
Try the 8gb pen drive in another usb port on the same computer, or try it in another computer to verify if it is recognized by another computer system.
If it doesn't recognize it, try to return or exchange it for one that is recognized by the computer.
Good luck on this one.
    Sergeant:
  • 223 Answers
Hi raju, i am happy to assit you , after plugging in the device go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.Try connecting the device again, i think this should solve the problem.
Good luck ! if you think your problem solved don't forget to rate
5 Suggested Answers
softwareguru
  • 78 Answers
SOURCE: 8gb Transcend Pen-drive is not getting detected
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Posted on Jan 03, 2010
bob_computer
  • 3153 Answers
SOURCE: Transcend 2GB jf v30 pen drive not getting detected in vista OS
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 10, 2009
Beni S-P
  • 1006 Answers
SOURCE: transcend 1 GB removeable Pen drive is not detected
The pen driver is ifected with virus.Just format it with CMD and ur problem will be solved
Posted on Nov 02, 2007
SOURCE: Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Posted on Oct 31, 2008
I HAVE 8GB PEN DRIVE, BUT IT IS NOT DETECTED BY MY PC
Try going right click on my computer, select "manage". then storage -> disk management, you might see it there, if so, you can format it, then your computer can detect it normally.
Jan 02, 2011 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
When i format transcend 8gb jf v10 it says disk is write protected. I'm not able to add data or format it please help..
I have purchased 8gb Transcend Pen Drive When i Connected the drive in computer a message shows "Please insrt a disk into drive". I have checked in several computers but the problem is same. Although the disk is detected but not shows the capacity when trying to open this message displayed. I have change the drive letter from my computer "Manage" option but the problem is same. What can i do?
May 14, 2010 | Computers & Internet
Transcend JetFlash V10 -8GB when opened shows ''insert disk''
your pendrive is out of order Transcend JetFlash V10 -8GB whenever you purchase a pendrive only
buy a 1,2,4GB
Jul 22, 2009 | Electronics - Others
Formatting the 8GB Transcend pen drive
check once whether u hv given read only option in properties
Jun 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
My pen drive is not being detected on computer
Hello sir,
You can recover by doing the following:
go to transcend website and download this software;
(http://www.transcendusa.com/products/online_recovery.asp) and then you have to select repair and save data..
and then also if you dont get ur full data,you can download (http://www.freedownloadscenter.com/Utilities/File_Cataloging_Utilities/Pen_Drive_Data_Recovery.html)
Pen drive recovery from many sites(search on google) and recover or else email me at devgolani@gmail.com for full software..
Regards
Devesh Golani
devgolani@gmail.com
Mar 24, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Jan 13, 2009 | Transcend (589307) Media
Transcend 8GB PEN DRIVE SHOWS PIS INSERT A DISC TO DRIVE.... CHECKED ALL VIRUS SCANE.. NOTHING HAPPENING
Is the hardware detected? If so, try formatting.
If not, you can use it as a keyholder or a door stop.
Good luck
Oct 26, 2008 | Transcend (589307) Media
Feb 27, 2008 | Transcend (589307) Media
Electronics - Others Logo
1,102 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
