Question about KitchenAid Microwave Ovens
I have a kitchenaid microwave, model number KHMS105BBL-5. It was working fine for several food items, and suddenly starting making a funny sound and producing a strong chemical burn odor, and stopping heating the food item. What do you think the problem is? Thank you.
MicrowaveSvc
  • 9047 Answers
SOURCE: My Sharp R-248h 800w microwave is not heating up any food items.
That sounds like it would be a 220V 50Hz model. I would assume you're using it with the correct power source or if needed, the right power transformer and/or adapters. I'm curious how you solved the touchpad control problem? When troubleshooting, I always first check an area that was worked on before if I know about it. That being said, the most common causes of the problem you describe are: - defective door switch (probably the upper one) - defective door switch mount - loose and tarnished connection at the FA terminal of the magnetron (disconnect, tighten, burnish, and reinstall) If you have sufficient experience and/or information, you can do it yourself, but I a microwave uses and produces voltages that can be instantly lethal. These areas can be safely checked if the oven is disconnected from the wall and the high voltage capacitor is properly discharged. Information on discharging the capacitor and testing these parts is available from various sources on the Web. Door switches can be obtained from a local appliance parts store. Good luck and be safe.
Posted on Nov 13, 2006
  • 579 Answers
SOURCE: How do I fix a Jenn-Air JMC7000 that does not heat up items?
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
  • 140 Answers
SOURCE: Microwave not heating food
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Jan 26, 2009
BNUTZBCRAZY
  • 130 Answers
SOURCE: microwave not heating items, also range vent not operating
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and other parts of the unit have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, they dont make them long lasting anymore, they are a "disposable" product these days
Posted on Jan 15, 2010
Food does not heat up anymore even when running
To correctly sort the problem out, you need to replace the magnatron and capacitor with the HV diode. That will definately sort the problem out. Do not do this repair without supervision as a microwave is truly a dangerous item to repair.(Make sure the plug is out when inspecting the components. You must be exact when ordering the componenents. Read off the numbers to the supplier to get the correct items.(Thats if you insist on doing it yourself).
Sep 03, 2010 | KitchenAid KHMS2050SSS Microwave Oven
The microwave runs but it doesnt warm up the food. it also is making a funny noise.
if the sound is a buzzing noise, it is probably your magnetron, most GE microwaves have a 5 or 10 year warranty on magnetron, all you may have to pay is labor
Aug 24, 2010 | GE Microwave Ovens
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave works, new noise
It could be a bad magnetron, or it may be mild arcing due to food particles or grease on or behind the waveguide cover.
No microwave should ever be left unattended while running.
Jun 24, 2008 | Microwave Ovens
Kitchenaid microwave/oven combo model KEMC308KSSO
The keypad circuit board must be replaced to start. Sometimes, the fault can also be on the main processor board.
Jerry G.
May 15, 2008 | LG LMV2055ST Microwave Oven
Kitchenaid model:KHMS105B microwave hood combination
hi alan,
it sounds like the transformer is bad, which makes this easy, time for a new one. 12yrs is a good age for a microwave, average life is about 8-10 yrs!
Mar 21, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave not working
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 30, 2007 | Microwave Ovens
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
