Question about ASUS P5GD1-VM Motherboard
My computer runs normally.. all of a sudden, my computer stops working. i try to power on the computer. nothing happened as it is dead. i remove the side cover. the green light for the motherboard(P5GD1-VM) is on. but when power on... nothing works. please help me... is my motherboard dead?
  • ASUS Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Jan 02, 2011
Acer AM1100-E1304a do not start.
Try removing the battery. It may be the battery is eating all the power that the supply can produce, leaving nothing to run the computer. That could happen with a shorted cell or a completely dead battery. IF the power supply you are using is the correct one for your laptop.
Oct 27, 2014 | Computers & Internet
Suddenly stopped working, not charging.
it is possible that the bluetooth connection being cut midcall to have froze the bluetooth headsed, one thing you should try is to power it up in connection mode and see if it works, there are different combinations of buttons, assuming you have power and volume buttons to do a hard reset to it... otherwise i think you should take it where you bought it and ask for solution even if warranty period is over because it simply isn't normal what happened.
best of wishes and hope i helped. good luck
Mar 10, 2014 | Motorola Mobility HK202 Bluetooth Headset
Samsung laptop problems
try cold reset by removing the battery including power adapter then press power button for approx. 20 secs. then plug your power adapter then press power button again. press the numlock/ capslock button if there is response showing that your motherboard isnt dead yet. please check also when fan is running momentarily then suddenly stops then post another question here.
Dec 02, 2013 | Computers & Internet
HP Pavilion a6602f suddenly stopped working for no apparent reason.
Hello there, I am the Expert that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Debdeb_64.
The power supply could be ok, this little green light that you see on the rear of the tower case is likely to be the Ethernet/Network connection.
Possible reasons for failure are as follows:
It could be a loose connection at the 24Pin or Processor 4Pin power connector.
A damaged power supply, is possible.
A faulty power on switch.
A dead mainboard.
A loose connection.
I have published a few guides that should help you in this regard, they are entitled:
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
and most importantly My Computer is not turning on!!! Is it dead!!! No POST!!!
Do contact a computer technician to test components if need be.
Take care!
Feb 03, 2012 | Computers & Internet
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
I have a hp pavilion dv9000 laptop and it wont even turn
If you tried it witht he adapter then sounds like the motherboard is dead.
May 17, 2009 | HP Pavilion dv9000t Notebook
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
ASUS P5GD1-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
