Lost the plastic sheath for the Pandiigital one touch scanner
Check out Ambir technology website. They have 2 for $5.00. Shipping is $12 though. A local photoshop (if you can find one) may be able to help.
Posted on Jan 02, 2011
Are replacement plastic sheaths available for this product
Not ment to be replaced. Scanners are very very cheap now. Just replace the scanner.
Jun 26, 2016 | PANDIGITAL Scn02 Photolink One-Touch...
What is the part called it the clutch cable is inserted to on a 2000 suzuki katana 600
The cable (long, bright, shiny, braided/twisted wire) is inserted into a sheath before the two end pieces are crimped onto the cable. The sheath or housing is the black plastic tube that houses the cable.
Jun 13, 2014 | Motorcycles
Replace the motor shaft cover on cuisinart dlc 7
I have a DLC7pro from around 1982 that I just replaced the sheath on.
To remove the sheath I use a small pipe cutter and took the sheath off in approximately ½ inch sections. Once the circular cut was complete I used a plier to pull off the section. - This method worked GREAT! Be sure you get ALL of the white plastic off and be sure to remove the ½ inch brass "ring" which is part of the old sheath. Also, make sure no plastic "crumbs" are in the base of the shaft where the new sheath will sit. You will see that the metal shaft has a flat side. With a sharpie marker, mark the metal shaft near the base to indicate where the center of the flat side is.
When you look at the replacement sheath, you will notice flat sides on the outside of the sheath. If you look inside the sheath, you will see two "nubs", these nubs form a flat inner side of the sheath . Unfortunately these nubs do NOT line up with the flat outside sections. Use a sharpie marker to mark the center point of the two inner nubs. The inner flat side HAS to match up perfectly with the flat side of the shaft. The marker helps you do that.
Line the inner flat side of the sheath up with the flat side of the metal shaft and push the sheath on your hand as far as it will go. It should go about an inch from the base.
Put the base on a mat on the floor ( you don't want to damage your floor) . Next you will need a hammer, piece of 2x4 wood and BRUTE STRENGHT! - Please note that once you hammer this, even just one strike and the sheath will NOT come off. Put the 2" side of the wood against the top of the sheath. Using more force than you think you should need - strike the wood to hammer the sheath all the way down. It should take 3 - 5 very hard strikes. If the base of the sheath rubs on the bottom of your workbowl - they will fuse together, so be sure the sheath is seated as far down as you can get it. Again, it takes a LOT
Dec 06, 2010 | Cuisinart DLC-10S Pro Classic Food...
Replacements?
If you go to www.pandigital.net and click on all personal photo scanners/converters, you'll see a picture of your scanner. Click on it. Scroll down to the bottom of the page and there'll be options including downloads. Click on downloads and you'll have to know your product specifications to get the right one, but the manuals are all there, in all languages, so make sure you get English. Hope this helps a little.
Jun 18, 2010 | PANDIGITAL Panscn02 Photolink Scanner
I lost my scanner icon from taskbar scanner will not work properl
Right click on the taskbar go to properties then click on customize button and select the appropriate icon u want.
May 01, 2009 | Office Equipment & Supplies
Want to install my scanner. Visioneer one touch 5800
ok do u have driver cd or not first tell me if yes u can put up the cd in cdrom and install the scanner driver after the driver install your scanner automatic.. if you have no cd pls tell me which com u have scanner ok
Apr 15, 2009 | Office Equipment & Supplies
Audi A6 rear seat problem
The rear seat pulls out easily.  Grab the front of the seat with fingers under seat on driver side and pull up hard.  do the same on the passenger side and it will unclip.  Then you can move the seat around to get to the buckle.  Install by inserting rear end in first and lineing up the metal tabs w/ the female plastic inserts in the floor and push down hard until it snaps into place.
Mar 28, 2009 | 2006 Audi A6
Cozy wall furnace - unattached wire, won't turn on
Sounds like one of your limit switches lost it's wire. Look for a disc like device no more bigger then a 50 piece. You will see two wires going to that and if the wire broke take off the insulation and install new plastic sheath and re-attach. Let me know it that is helpful. ken
Nov 23, 2008 | Cozy (W352E) Heater
Xerox One touch 2400 scanner
Go to xerox.com. And click on Support and drivers, then scanners and peripherals.
I also have paperport deluxe 8.0 disks out the ear.
If you want to give me your E-mail address and I can make arangements to send one to you for the price of shipping.
Apr 22, 2008 | Xerox One Touch 2400 Flatbed Scanner
80 people viewed this question
k24674
jasbo
jasbo
