Washing machine does not drain water after washing what will i do?
    Scholar:
  • 177 Answers
Check if the lid switch is ok. Some machines will not drain or spin if the lid switch is bad. Also a hose could be stopped up . Should be a hose from the tub to the pump it could have a sock or something in it. Something could be stopping the pump from turning or hose from pump to drain could be stopped up.Check if the motor is running when it should be draining. If motor not running could be bad connection to motor or timer. If connections are ok it could be the timer. If the motor is running is the pump turning? Make sure the drain to the sewer is clear. Hope this helps.
Posted on Jan 02, 2011
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
